i don't know what happened but i can't play AVI Files in any software i try
the hole computer stuck and then the software stucks too!
TNX for your help
Closed Thread
Results 1 to 9 of 9
For the avi ... if that is what they truely are ? ... then gspot can be used to tell you if you have the correct decoder's installed ... if not , it will say so .
See if the "avi" can be opened in vdub ... again , if gspot said decoder unavailable , then you should visit the tool's section , codec's ... be aware of "all-in-one" pack's ... best stay clear of these thing's for now .
There is also a "codec snipper" , allowing you to disable codec's ... however this is not a newbie freindly method ... and as I have never needed to use such tool's to perform such function's , I am unable to advise you as to how to proceed ... other's may beable too .
I am just wodering , have you used "system restore" ... if so , this replace's the registry with previous version , and any program's installed after this restore point have all there executable's nulled (nolonger function) , thus it's goodbye too certain registry key's ... guaranteed method to breaking thing's ... especially anything video related ...
Stupid ms need's to warn people of that thing ... preferably now ... I'll phone them tomorrow about that crap ...
If you do have a restore point available , before using it , uninstall any program's that had been installed after it ... reboot pc ...
Write down any detail's you need a backup off ... just incase ... dialup account info would be a good thing to backup ... if you use it ...
Then use system restore ... this should return pc back to "normal" ... a rather ambiguous description when ms is involved ... and hopefully you will beable to get avi back up and playing .
Beyond this failing ... a complete system reinstall will cure all issue's ... sometime's the problem is so "ingrained" it is the only method left ... and perhap's the quickest .
I also can't plat AVI files .... but then again, I can't plat hair either, and I'm certainly no hairdresser
GSpot your AVI(s), and find out what codec(s) they use. Then try DXMan and or CodecSniper, and check the "health" of said codecs. Please don't say that you installed a codec pack, either. Maybe try reinstalling affected codecs. Maybe also try a software such as VideoLAN or Media Player Classic - both of which I believe use their own codecs. Some sort of indication of the name of the software that locks up might be helpful also.If in doubt, Google it.
This is an upload of the gspot and the codecs that he found/didn't found in one of my movies..
i have to say that this happens to me in all the movies!!!
TNX for your help
Here:
I can't understand what's wrong!!
You are in breach of the forum rules and are being issued with a formal warning. Please read the Rules about warez, thanks.
/ Moderator offline
Buy this on DVD and allllll your problems will magically disappear
Vegas Studio Plat: DVD files to HD?
By OldNick in forum EditingReplies: 71Last Post: 2nd Apr 2012, 18:38 -
Sony AVCHD to AVI via Sony Movie Studio Plat. 8
By herzeleid in forum Video ConversionReplies: 0Last Post: 22nd Nov 2008, 13:04 -
Final product from Vegas studio 8 plat. Too big
By Jensen in forum EditingReplies: 4Last Post: 17th Jan 2008, 19:23 -
Does WinDVD8 gold or Plat allow full screen pic ?
By DBenz in forum Software PlayingReplies: 3Last Post: 13th Jan 2008, 19:51 -
Dvdfab Plat. Question
By joelw_7 in forum DVD RippingReplies: 1Last Post: 13th Dec 2007, 08:23
