Hey
I was wondering how do u play avi files on dvd players. I've heard that u use nero to burn it into VCD...How do I do that? I'm new at this..so yeah.
Thanks mucho u guys![]()
You can
Use Nero to create a VCD (low quality, limited capacity)
Use DivxtoDVD to create a DVD (much better quality, up to three hours to a DVD)
Use a divx capable to dvd player to play the original files from a data DVD.
All of this is covered to some dgree in the guides to your left <-
Just look up the conversion you want and dive in.Read my blog here.
Select VCD in Nero Burning Rom or Nero Vision and add the avi and burn...
Or if you have a dvd writer use instead ConvertXtoDVD and make a DVD from the AVI.
Or if you dvd player supports divx then it might be enought to just burn the avi on a cd / dvd. -
ok so i tried Nero Vision....and my computer went wacko. It didnt burn it. Then i tried ConvertXtoDVD, it did convert it and burn it to the cd. But the problem was that it didnt play on my DVD player....
Thanks though. -
Which DVD player do you have?
If cameras add ten pounds, why would people want to eat them? -
I hope that's a typo. Most DVD players won't play DVD on CD. Of course, some won't even play burned DVDs either. Depends on your player. Hence Ai Haibara's question.
Another H264 to AVI Question
By kenzier in forum Video ConversionReplies: 4Last Post: 20th Feb 2011, 01:59 -
question about avi files
By tlrbjc in forum Newbie / General discussionsReplies: 5Last Post: 17th Jul 2009, 14:54 -
VOB to avi question
By nalooti in forum Video ConversionReplies: 2Last Post: 3rd Jul 2009, 18:16 -
For VOB files to AVI, I use avi.net . . Question
By nhbfan12345 in forum DVD RippingReplies: 4Last Post: 11th Sep 2008, 00:02 -
AVI to DVD question
By cajmere in forum Video ConversionReplies: 3Last Post: 6th Dec 2007, 15:29
