hi, my dvd's look fine on my 19inch 1240x1024 (maybe the 1240 was different) but upconverting, is that gona be just for bigger screens and does my x-box 360 do it, no where says if it upconverts dvd's, ive searched for 30mins
Most LCD and Plasma screen with much laerger apparent real estate - say a 40 or 50 inch - actually have a lower real resolution than your monitor.
My reading of their propoganda is that it acts as a standard resolution, progressive DVD player. No upconverting. This doesn't surprise me, as they will be wanting you to by the HD DVD add-one when it becomes available if you want these features.Read my blog here.
i think i saw one bullet point saying it makes ur dvd's look better but no real facts
I can make DVDs look better simply by wiping dust off my tv screen.Originally Posted by slimpickins
i can save time by spraying my screen with anti-dust polish therefore saving time to watch a dvd
Help capturing xbox 360 video when xbox is connected to monitor with vga
By laldabomb8 in forum Capturing and VCRReplies: 0Last Post: 23rd Jul 2010, 03:05 -
xbox 360 subtitle DVD
By vidm in forum SubtitleReplies: 5Last Post: 12th Jun 2010, 12:41 -
how do you record xbox 360 gameplay while using microsofts xbox 360 vga ?
By rushinplaya in forum Capturing and VCRReplies: 18Last Post: 3rd Apr 2010, 07:19 -
Xbox 360 HD-DVD Player on PC
By WiReTaP in forum User guidesReplies: 48Last Post: 26th Dec 2008, 13:35 -
Can you interchange a xbox 360 hddvd drive between pc and 360?
By yoda313 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 23rd Oct 2007, 10:06
