hi, jsut placed an order for an x-box 360, can i back-up games, how come on torrent sites ive seen games in brackets (xbox360), im not gona download them, but can i back-up my own games, or even old dvd games for the original x-box
Sure you can back them up. Getting those backups to work is a hardware issue where you will need a mod chip to do so. Some soldering and assembly required.
Dunno about the 360, but with "Series I" XBOXs you could FTP to your XBOX and copy the files from the DVD Drive to your computer. Then use GDFImage to "reverse" compile an ISO image fit for burning to disc (long story short, but with XBOX games the data is read from the outside in, therefore you need a mechanism to "mirror" the ISO image such that when a DVD writer writes it from inside out, it appears OK to the XBOX). You definitely need a chip or other mod to be able to play burnt games, and maybe to set the IP address.Originally Posted by slimpickinsIf in doubt, Google it.
Is it possible to extract video files from XBox 360 / Playstation 3 games?
By Daniel_BMS in forum Capturing and VCRReplies: 0Last Post: 2nd Apr 2012, 23:15 -
Help capturing xbox 360 video when xbox is connected to monitor with vga
By laldabomb8 in forum Capturing and VCRReplies: 0Last Post: 23rd Jul 2010, 03:05 -
how do you record xbox 360 gameplay while using microsofts xbox 360 vga ?
By rushinplaya in forum Capturing and VCRReplies: 18Last Post: 3rd Apr 2010, 07:19 -
Can you interchange a xbox 360 hddvd drive between pc and 360?
By yoda313 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 23rd Oct 2007, 10:06 -
Backup PS/XBox games?
By bad57 in forum Newbie / General discussionsReplies: 2Last Post: 11th Jun 2007, 04:11
