    Jun 2006
    For some reason when I play any .avi file I get this displayed in the top left corner:
    Current frame
    CPU load
    Input Size
    Output Size
    Only in .avi files
    At first I thought it was just in WMP but it also appears in divx player
    How do I get rid of it?
    Jun 2004
    Victoria, Australia
    Sounds like you might have the OSD (On Screen Display) filter enabled in ffdshow...
    Trev
    Jun 2006
    At first I didn't think you were right because I didn't even have ffdshow installed but then I went ahead and installed it and the OSD checkbox was checked. So I unchecked it and now current frame disappeared. How could it have been turned on without me even having ffdshow in the first place?
    Weird.
    Thanks a lot man.
  4. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    You must have had it installed. Used some codec pack maybe?
    /Mats
    Jun 2006
    I did have xp codec pack installed. That is probably what caused this.
    Thanks.
