Hey guys, got another question for ya. So I'm using VDubMod to add black borders to my fansubs: rez is increased from 640x480 to 700x526 (with borders) and recompressed using DivX 6.1.1. When I try to use NeroVision Express to burn the black-borded-fansubs to a DVD, the files are being badly distorted (the image slants about 45* and whatever is cut off of the right side is being displayed on the left side). I was wondering if someone knows why this is occuring and what I could do to correct it.
OMGWATERGUNSQUIRTSQUIRTSQUIRT
Assuming NTSC source, 640 x 480 (1:1) is equivelent to 720 x 480 (NTSC D1). By resizing to larger than 640 x 480 you are forcing Nerovision to resize down again to fit the screen. Recompressing to Divx along the way probably isn't doing much for image quality as well.
That said, if Nerovision is butchering the video then it is having problems with with Divx 6.1.1 video, or the resize. You coul dtry encoding with Xvid, to see if Nerovision reads it better, or ditch Nerovision for a btter tools.
The best solution to the fan-sub catastrophe is still FitCD, avisynth and a good encoder.Read my blog here.
Guns1inger, you rock. I'm gonna give this a try later tonight, thanks for all the help you've given me.
Can't cut part with vdubmod?
By kkiller23 in forum EditingReplies: 1Last Post: 19th Sep 2010, 07:15 -
The Resolution Conflict
By AscAnsio in forum Video ConversionReplies: 4Last Post: 8th Jan 2010, 08:51 -
Vdub vs Vdubmod vs Vdubmpeg2
By schematic2 in forum EditingReplies: 9Last Post: 17th Jul 2009, 13:09 -
can't open any videos in vdubmod 1.5
By mr-scarface in forum EditingReplies: 8Last Post: 18th May 2009, 04:53 -
vdubmod crash
By RobMan in forum SubtitleReplies: 4Last Post: 31st Dec 2007, 08:22
