Hi
I have a mpg1 file that I try to convert to mpg-2 using tmpgenc
when I try to convert it it give me a streaming error and it won't convert the file.
There is probably a problem with this file because i have been converting these king of file
for about 20 times.
I have no problem reading this file with media player classic
I would like to know if there is a way I can convert this file by solving the problem in the file
maybe there is a few bad frame in the video.
So if anyone can help me with this issue
I would appreciate
thanx
Try opening the file in virtualdubmod and go to check errors. Then you can see if there are bad frames.
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
I download and install the program
open the video file
and then lunch the
video... scan video stream for errors ... scan
What should I do after to correct the file or create a new error free file ? -
Maybe some of these will help:
https://www.videohelp.com/tools?s=12#12
https://www.videohelp.com/edit#5;22
BTW, Virtualdub (and its variants) are probably more helpful when the source is AVI, since it natively will want to output AVI. However, you can frameserve from virtualdub to an MPEG encoder if MPEG is your output choice.If in doubt, Google it. -
For what appear's to be broken block's in both mpeg's and avi ... even mov's ... re-encode it via super .
There is an mpeg properties tool in tool section , use it to find out the video and audio bitrate's first .
Set output as mpeg .
Set no change to video scale .
Aspect should have no check's .
Place "known bitrate" in bitrate .
Hq if you want .
Audio out as mp2 (easier for vdub to work with)
Set bitrate to "known bitrate" from mpeg properties tool .
Or , set to no lower than 96 ... higher is better .
Hit "encode now" and wait .
One issue remain's in super ... do you see what I mean ?
No 24 frames/sec ... lame ... need to reclock the video after .
In the case you video is any other fps not listed in super ... convert to avi .
Use same video setup ...
Output is avi
Codec is xvid
Audio is mp3
Double that mpeg video bitrate .
Audio sample as 44100 .
No lower than 96 kbps .
Encode .
Open avi in vdub .
Video - hold ctrl , and press r .
Second edit box in new window
Set frame rate to that of the original mpeg .
Click ok .
Video to direct stream copy .
Audio to full processing .
Audio - compressor
Chose mpeg layer 3 (48kbit/s , 24,000hz , 6kb/s - highly compatable for mpeg4 player's)
Save as avi , name it and go ... wait .
As for conversion of the known framerate to other ... most tool's get this wrong , or user's try to apply specific trick's .
I prefer ulead video studio for this , never an issue ... "9 se" cheap in ebay ... considering what you get for the price , it's a bargain .
Version 7 se ... require's two updated dll's ... saving split video clip's broken under xp .
Version 8 se ... require's a 110mb download to fix filter's issue ... got me buggered , never had an issue with them .
Version 9 se ... unknown ... support's many format's as input and output ... wmv hd ... it's bonker's ... user has control over output specific's if custom format is chosen ... burning vcd , dvd ... share video online ..
Add a few free tool's , and you have all you may ever need for xvid , divx to cd ... pal / nstc to vcd/svcd/dvd ...
Vhs just finished recording from the dvd ... perfect ... off to see if my other theory work's now that I have a screwed up out of snyc video to practice with .
Help converting mpeg type video with correct frame rate
By DJX in forum Video ConversionReplies: 0Last Post: 9th Oct 2010, 18:24 -
Is there an easy way to determine the frame size of videos?(avi, mpg, etc)
By True Colors in forum Newbie / General discussionsReplies: 2Last Post: 17th Apr 2010, 15:45 -
MOV to MPG - White frame inserted in loop
By lgare in forum Video ConversionReplies: 1Last Post: 29th Jan 2010, 07:56 -
How can I cut out an image from a mpg file? Just one frame
By szalaikornel in forum Video ConversionReplies: 4Last Post: 28th Jan 2009, 10:59 -
Correct Terminology for a menu frame that shows a clip from the movie
By gayclarke in forum Newbie / General discussionsReplies: 3Last Post: 14th Aug 2007, 08:19
