I have a large collection of various .WMV files that are different clips, lots of different sizes, probabl various frame rates.
What would be the easiest way to:
Convert all the videos to 704x480, 29.97 VOBs. Keeping the aspect ratio correct AND adding padding for a TV-safe area. Then concatentate (add) them all together into one clip with a chapter boundary set at the end of each clip.
Is there a batch conversion program that will handle multiple resolutions and A/R's and output a file with all the same dimensions, the same framerate, and WITH a TV-safe area?
Most, if not all, of the clips are 640x480 or lower..... VCD resolution mostly.
CLI program would be fine as long as I can control it the way I want it....
If I cannot get a better solution, I will simple resize everthing to 704x480 with tv-safe area, ignoring aspect ratios. Not an ideal situation, but better than one-by-one.....
I am very rudimentary at avisynth scripting, but I would guess I could do the resizing with bars, etc. by formulas?
Donny
Batch converting...
By finey in forum Video ConversionReplies: 6Last Post: 31st Jan 2009, 17:01 -
batch convert avi's to DVD size
By milofhead in forum Newbie / General discussionsReplies: 2Last Post: 17th Nov 2008, 08:51 -
Batch converting
By Dave H in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 3rd Nov 2007, 06:50 -
files sizes, converting, uploading
By debrag in forum Newbie / General discussionsReplies: 7Last Post: 1st Oct 2007, 05:03 -
batch convert avis to cd size
By clawg in forum Video ConversionReplies: 2Last Post: 25th Jun 2007, 12:27
