New to the Mac world and was wondering, using final cut studio, is there an easy way to get the iDVD themes into DVD Studio Pro? From what I understand, You have to create a iDVD project and then import it into DVDSP. Do I need to create a full project with a movie or can I just create a project with a menu theme and import into DVDSP and add my movie? OR is there an eaiser way to do it, if it can be done at all.
Results 1 to 15 of 15
"Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
Thanks,
I will try this tonight, I couldn't last nite because I was encoding. -
The limitation on this (according to Apple—I haven't tried it) is that the current DVDSP will only open iDVD6 themes (or projects).
yes, this is true. I did a test from iDVD 5 of the Cinema template,Originally Posted by AntnyMD
saving it in a project and opening it up in DVDSP3.
worked fine."Everyone has to learn, so that they can one day teach."
Urban Mac User -
I also tested opening up an iDVD6 project using a iDVD4 theme and opening in DVD Studio Pro 4. DVDSP4 will not open any project created by iDVD6, no matter how old the theme is.
So if I'm using DVDSP4.0 and have ilife 06 What I am try to do will probably not work?
Must be a limitation in iDVD 6.
Since I don't have iDVD 6,
I can't test.
( I only have iDVD 5 as a fluke,
I don't use it since moving to DVDSP).
follow this thread in the Apple discussion boards, may help:
idvd6 and dvdsp"Everyone has to learn, so that they can one day teach."
Urban Mac User -
So I would be better off to to go backwards to iDVD5? Can I do this or do I have to us the whole ilife 05 instead of ilife 06?
once you go DVDSP, you won't go back.
at least that was how it was for me...."Everyone has to learn, so that they can one day teach."
Urban Mac User -
And I will probably agree with that 100%. I am used to DVDlab on a PC and editing with Premiere Pro. So when switching to a Mac, iMovie and iDVD seemed to be a big step backwards. I just thought that iDVD had some cool themes in it and if I could use some of them I would, when I got into iDVD it just didn't seem as straight forward to me as DVDSP. I'll probably just try and play with iDVD IF I ever get time. Which will probably be awhile anyways.
For now I'll just stick with the DVDSP templates and modify them as needed for quicker projects. I'll eventually get to the point where I'll create my own in DVDSP and or Photoshop.
Avid Studio vs. Sony Vegas Pro/Studio
By HoosierGuy in forum EditingReplies: 12Last Post: 8th Dec 2011, 20:06 -
Import Premier Pro 1.5 Project into Final Cut Pro/Studio 3 - how please?
By rjamesd05 in forum MacReplies: 1Last Post: 6th Sep 2010, 13:50 -
IDVD themes
By greeneyes21 in forum MacReplies: 3Last Post: 21st Jan 2010, 20:05 -
DVD Studio Pro
By macuser1960 in forum MacReplies: 3Last Post: 12th Mar 2009, 07:45 -
From EyeTV to DVD Studio Pro or iDVD
By fredericvo in forum ffmpegX general discussionReplies: 11Last Post: 22nd Apr 2008, 16:14
