After yelling, pulling hair and almost throwing my computer out a window, i FINALLY figured out how to add subtitles to an avi while encoding it to DVD and I felt I should post and maybe save someones poor computer from the fate mine almost met.
I started with an avi file and an idx and sub file. I installed VobSub (https://www.videohelp.com/tools?tool=VobSub), now I was able to right click on the idx file and chose 'edit with SubResync". From there I was able to save it as an srt. All of these files (idx, sub & srt) have the same name as the avi file it goes with.
I then installed ffdshow (https://www.videohelp.com/tools?tool=ffdshow). Once install I went to programs/ffdshow/video decoder configuration. i then click 'subtitles' on the left hand side, and then highlight 'subtitles', this should bring up the subtitle configuration. I then checked 'subtitles' on the right near the top.
Once I did all this, i was able to open my Ulead DVD Movies factory and 'poof' my subtitles were there.
maybe I did too much, I am not sure. But while lookink throught this site all I found were lenghty 3-5 step processes that didn't seem to get me anywhere. Most of them were for removing a subtitle from a DVD and adding a new one.
I also tried the VirtulDub method only to find that my new avi was choppy and out of sync. I know there are settings to fix this, but when you are dealing with someone with limited knowledge of the process, that can be worse then the 3-5 step precesses.
I hope this is helpful to someone, and if I did too many steps or if there is an even easier way, please post and help out some poor computer that may be headed out a window.
:P
I use DVD Lab Pro to author. I can have multiple subtitles, all switchable. Easy to author and much more flexible.
Read my blog here.
How can I rip DVD to AVI and make each chapter a seperate file
By mikeyshine in forum DVD RippingReplies: 10Last Post: 23rd Sep 2011, 15:02 -
Found DVD/AVI software player that displays Chinese srt subtitles with avi
By jimdagys in forum Software PlayingReplies: 1Last Post: 14th Nov 2009, 20:45 -
Converting AVI to MPEG-2 with no seperate audio file
By Craig876 in forum Video ConversionReplies: 1Last Post: 9th Nov 2009, 18:38 -
Converting AVI to DVD plus Subtitles (Loss of quality on subtitles)
By somenho in forum ffmpegX general discussionReplies: 2Last Post: 27th Aug 2009, 10:23
