  1. hi everybody out there
    I bought a AKI DVD Player that looks exactly like the optim DS8302 player, but the hacks found on vdchelp.com doesn't work...
    Has anybody of you a tip for me?
    Daniel
  2. Hi Witneyfan, ok you may have by now the codes you were looking for ,but i have codes here that you can try anyway.
    Open you DVD drawer before entering the code
    OK to set the region code just key in 8,4,2,1 with your remote you can select any Region you want or select to play all
    Next up is for Macrofree with you remote agin key in 6,8,6,9 then you can enable or disable Macro whenever you like,Hope this helps.
    Scottie
