welp, i read the tutorial about merging avi
http://www.doom9.org/index.html?/virtualdub_procedures.htm
and after the 2nd step trying to select the avi file, it gives me this error:
Cannot append segment: the video steam have different formats.
after that i tried with a different avi , another error:
Cannon append segment: the video steam use imcompatible compression types.
how do u fix this? i need help asap i need for a school project!
Hi-
Unfortunately, you can't easily fix it. To join AVIs, both have to be of exactly the same type, have the same resolution, audio, audio sampling rate, etc., etc.
If one is DivX and the other XviD, for example, you can reencode one to the same codec as the other. If one is of a different resolution from the other, it can be reencoded to the same resolution. You can check the AVI properties in something like GSpot and see exactly what the differences are, and then decide whether or not you want to try and fix them. Unless you're pretty experienced, this can be kind of tricky.
One thing you can do, although it may not help you, is to set up a playlist using a player that supports playlists, like BSPlayer. Then you don't actually join them, but one will play right after the other. -
well im trying to make into a dvd right , so if merging into one file doesnt work, then how u put numerous files into one dvd?
you got a tutorial or something? im kinda new burning things... so i have no clue encode or authoring means
Hi-
How were you going to do that, if you don't know how to encode or author? In this case, instead of encoding one video, you'll be encoding multiple videos. Same principle. There are a ton of guides listed in the guides section. I'd suggest you start reading, perhaps the What Is DVD page linked over on the left. -
Read my blog here.
merging avi's with different resolution without quality loss
By surfer in forum EditingReplies: 16Last Post: 21st Aug 2011, 23:56 -
Edit Avi: VDub / VDubMod / Nandub
By Rinsin in forum EditingReplies: 11Last Post: 1st Mar 2010, 17:33 -
Quality problems after merging two .avi files
By Metallo in forum EditingReplies: 14Last Post: 13th Aug 2008, 09:50 -
Merging AVI Clips
By Soccerman77 in forum Video ConversionReplies: 3Last Post: 26th Nov 2007, 16:10 -
Problems with merging to avi files
By mingul in forum Video ConversionReplies: 3Last Post: 6th May 2007, 10:06
