Im using ffmpegx to convert some mpg and mp4 files to mpeg-ts so I cant put them on my Topfield PVR.
Anyway I have made some smaller files convert ok, up to about 600mb. But I have a couple of 1gb plus files, the convertor works ok until it gets to 100% but then comes up with failed, it leaves me with about 4 files instead of the usual 1 when it works.
Ive tried using quicktime to split the file into 2 smaller ones, but the conversion still fails.
Anyone got any advice?
What error messages do you get in the process info dialogue?
You might have a time code issue. Try running the files through MPEGStreamClip and fix the time code breaks.
I have not used ffmpegXfor creating MPEG_TS files, but it really does sound like a time code break issue. Try running the file through the fix function in ffmpegX tools, or use MPEGStreamClip (fix time Code Breaks.)
AVIdemux keeps crashing
By gastrof in forum Newbie / General discussionsReplies: 2Last Post: 31st Jan 2012, 13:32 -
MeGUI crashing
By socrates in forum Video ConversionReplies: 0Last Post: 10th May 2011, 04:49 -
x264 keeps crashing
By MR 3 in forum Video ConversionReplies: 6Last Post: 17th Jan 2010, 14:29 -
system crashing
By alintatoc in forum Newbie / General discussionsReplies: 11Last Post: 6th Apr 2009, 08:03 -
Staxrip keeps crashing on me
By doggyjumper in forum Video ConversionReplies: 2Last Post: 4th Aug 2008, 18:45
