Does anyone know how I can fix broken AVI's? I have a few that need to be fixed before any programs will let me convert them to mpg.
It all depends how they are broken, but a very good little program called DIVFIX will strip and reconstruct the avi index allowing them to play. I routinely perform this on any downloaded divx avi's, it sometimes corrects audio sync due to 'frozen' frames (make a backup though, as it does change the avi). You should find it easily enough with a google search (as i did!). Hope this helps.
p.s. if it finds corrupted frames it cannot magically replace lost data but will usually allow them to be played.
repairing a broken AVI file
By p_s_92 in forum Newbie / General discussionsReplies: 27Last Post: 29th Jul 2018, 16:42 -
how to fix broken avi seeking?
By muffinman123 in forum Newbie / General discussionsReplies: 1Last Post: 9th Dec 2011, 17:40 -
HD recovery -> broken AVI files
By tcglog in forum Newbie / General discussionsReplies: 2Last Post: 1st Oct 2010, 16:48 -
fixing suffled AVI
By fred3f in forum EditingReplies: 7Last Post: 13th Jan 2010, 22:54 -
AVI Broken or dosen't play??
By xeroid in forum Newbie / General discussionsReplies: 10Last Post: 23rd Oct 2008, 19:40
