Hi i have a problem i have a movie converted to mvcd format and when i watch it on my pc the audio is matched up with the video well but when i burn to cd using nero burning rom it throws the words off of the persons mouth any suggestion i am going to try vcd easy will that be better thankyou in advance for any help
Most likely not the burning process as such. I suspect that since a mvcd video is non standard video your DVD player can not handle it or else Nero is turning it into a VCD.
K-Lite Codec Pack messing up burning IMG audio cd burning
By Blå_Mocka in forum AudioReplies: 24Last Post: 26th Aug 2010, 06:27 -
Iso burning faile, folder burning succeed
By cd090580 in forum DVD & Blu-ray WritersReplies: 5Last Post: 3rd Dec 2009, 15:46 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
burning mvcd with Nero 8 Essentials or ???
By Jim S. in forum Newbie / General discussionsReplies: 3Last Post: 7th Apr 2008, 06:52 -
Advantages - disadvantages to burning video folders or burning an ISO img
By theewizard in forum Authoring (DVD)Replies: 14Last Post: 26th Jun 2007, 16:19
