  1. I have actually posted this before, but since no one seems to have the solution yet, so I re-post it again to try my luck.
    I have some AVI files captured (thru 1394) from my Sony DV. Then I try to cut/edit it by virtualdub. However, I encounter such an error message
    ** Quote **
    Couldn't locate decompressor for format "dvsd" (unknown)
    VirtualDub requires a Video for Windows (VFW) compatible codec to decompress video. DirectShow codecs, such as those used by Windows Media Player, are not suitable.
    ** Unquote **
    My PC is running Windows 2000.
    I heard that Virtualdub in itself cannot handle avi files from DV. Does anyone have any idea how I can get the codec required to do this?
    Thanks a lot.
    - David
  2. found this page inwhich someone asks the same question. The answer is as follows
    Please download and install Avisynth on your PC.
    Afterwards, save a textfile with content
    DirectShowSource("c:\Path_And_Filename.avi")
    Save this file as Video1.avs
    Start Virtual Dub and open this
    AVS-Textfile (like it were a real AVI-File).
    Virtual Dub opens the DVSD-File now!
    You can now convert the DVSD to the required compression, it worked correct with DivX 4.12
    on my Notebook.
    I found this Tip searching the Web with
    "DV to DivX". There was a Tip from Jussi Väisänen.
    It could work
    good luck
    baz
    <font size=-1>[ This Message was edited by: baz00ie on 2002-01-09 18:24:52 ]</font>
    <font size=-1>[ This Message was edited by: baz00ie on 2002-01-09 18:25:13 ]</font>
