Hi,
I just installed VirtualDub and tried to open an .avi video file. The program told me I need a codec to open it. What is a good codec to get for VirtualDub????
Thanks!!
And one more thing: try to install FFDShow. It has VFW-style codecs, which VDub/VDubMod likes, instead of the DS-style codecs (actually FFDShow has BOTH, but that's a different story).
I had to open an AVI with DIV3 and VDubMod won't open it until I went into FFDShow / VFW Codec Settings and turned on support for DIV3, and then VDubMod worked. -
You don't actually get a codec for virtualdub itself - you get a codec that is capable of decoding the AVI file in any program. This is where GSpot or AVICodec can come in handy as they can tell you what the AVI itself uses for (de)compression. Also have a look at http://www.fourcc.org and choose the video codecs option for a comprehensive list of what the fourccs represent, and what is recommended to use.Originally Posted by christopheramosIf in doubt, Google it.
VirtualDub Compression Codecs All missing?
By blazr in forum Newbie / General discussionsReplies: 0Last Post: 29th Feb 2012, 06:14 -
A few questions about bitrate,codecs and virtualdub
By alibaba12 in forum Newbie / General discussionsReplies: 21Last Post: 5th Jan 2012, 18:30 -
Codecs for WMM | WMP | VirtualDub
By TheGame111 in forum EditingReplies: 1Last Post: 22nd Dec 2010, 18:42 -
Codecs in VirtualDub
By TDT_99 in forum Newbie / General discussionsReplies: 3Last Post: 17th Jul 2007, 11:52 -
what is the best codecs to use in virtualdub
By demonwarrior in forum Newbie / General discussionsReplies: 4Last Post: 9th Jun 2007, 08:16
