Hi folks,
I've encoded a few avis into MPEG2 using ffmpegx. Usually, I just drop them into Toast 7 to convert to DVD with a simple menu, and it doesn't need to reencode them.
This time, I did the avis in ffmpegx's half-DVD format (352x480 or whatever it is), and Toast wants to reencode the MPEG2 files.
Is there a way, or an app, to fix the MPEG2 so Toast will multiplex them without encoding them again?
Or is there a free program to turn these 4 MPEG2 files into a DVD with a simple menu?
Cheers,
Bruce
There is something, audio OR video, that Toast doesn't like.
Could just be the size, if everything else matches to what
you have done previously.
I am assuming you had 4 AVis you wanted to make into
a DVD. The easiest way would be to just stitch the
avis together either into one or two avis, and then make
MPEGs from that, following settings for the mpegs obtained
by using a BitRate Calculator.
for instance, if you have 4 avi files, at an average of 41
mins each, then by stitching two together in QT pro would
make two avis at 88mins apiece.
If the taget goal is to avoid re-encoding in
Toast, then you would need to get the files to fit the
4340MB space of a DVD-R.
Going to a BitRate Calculator, if you add in the total amount
of video ( 88mins x 2 = 176mins/ 60min= 2hrs56min15sec),
set the audio to meet a bitrate of 192kbps, and with the
estimated size on disc meeting a minimum of 4340,
you would need to encode the
m2vs with a max bitrate of 5.5, a min target rate of 3.1mbps.
you set your encoding in ffmpegx to meet that target rate,
and when you build in toast, you will not have any re-encoding."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
Yes, I selected never encode, but it still does when it finds MPEG2 it doesn't like.
Urban Mac User -
352×480 goes for NTSCOriginally Posted by broaddd
352×576 goes for PAL
Need help to format and partition a 2TB HDD in half to fat32.
By s-toon in forum ComputerReplies: 4Last Post: 24th Sep 2010, 14:41 -
Fixing corrupted MPEG-1 VCD (freezing issue)
By headless chicken in forum EditingReplies: 11Last Post: 4th Sep 2009, 23:55 -
fixing bad sectors/Toast disk image
By danielmak in forum MacReplies: 6Last Post: 26th Jun 2008, 06:35 -
MPEG video stops half way through playback
By lpmitch in forum Software PlayingReplies: 4Last Post: 4th Apr 2008, 23:15 -
Fixing troublesome mpeg files?
By Hatecrime69 in forum Newbie / General discussionsReplies: 5Last Post: 4th Mar 2008, 17:41
