As title states looking for a divx/xvid dvd player with emphasis on divx/xvid capabilities. The Phillips 5140 seems to be a likely candidate but someone mentioned that the Pioneer DV-383 was also good as well. I'm looking for something with a new chipset/ will support the latest encodes and under $100 cdn which is ~$90 usd. I'm not a hardcore user but just looking for something good/cheap that will play my movies/tv shows and movies with subs.
Results 1 to 13 of 13
I will go for the Pioneer or the Liteon recorder/divx player (it was $99 few weeks ago at
bestbuy) I owned the Philips before (642) it was the worst player ever from bad quality build,
freezing with retail and divx movies(it was more than heat issue), and on top of that it came with 3 months warranty so that tells you a lot about a company that doesn't stands behind their products. You can also check amazon.com and see the old reviews. the 1st thing you read Dead after 3 months. Dead after 5 months…….you may find happy owners who get ez satisfied with any low quality crap(they will post here soon). whatever you choose. STAY AWAY FROM PHILIPS
Look at the Toshiba SD3990. $60 US. It's an excellent Divx/Xvid player.
Originally Posted by LloydAZ
Has anyone done an in-depth on the Toshi? How does it handle Qpel? I was just about ready to buy the LG LD-531, when it was discontinued and replaced by the inferior LD-731.
I have been VERY pleased with my Avayon DXP-1000. Bought a refurb unit for myself as a test, and bought a new unit for a family member.
www.avayon.com
Bonus (of sorts): Has karaoke feature, although some have reported the need to disable the karaoke feature to prevent some "stuttering" of playback. I have not had this problem at all. -
Originally Posted by handyguy
Originally Posted by CobraPilot
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 09:11 -
Divx/Xvid Player
By egweimai in forum DVD & Blu-ray PlayersReplies: 5Last Post: 14th Oct 2008, 09:54 -
Make an unplayable Xvid/Divx video play in a divx standalone Player
By AllenGorden in forum Newbie / General discussionsReplies: 4Last Post: 31st Dec 2007, 17:25 -
Best Divx/Xvid DVD Player!!!
By SIRCOOKS in forum ComputerReplies: 10Last Post: 23rd Aug 2007, 10:49 -
Standalone Divx/Xvid player Q
By g0dm0de in forum Newbie / General discussionsReplies: 3Last Post: 31st May 2007, 23:14
