I am looking for a software-based MPEG-2 encoder with the following features.
- The user can manually assign frames to either intraframe (I-frame), predicted frame (P-frame), or bidirectional frame (B-frame) of his choice. Therefore, the length of GOP may vary.
- A standalone application but not a plug-in.
Any suggestions? Thanks in advance.
Results 1 to 9 of 9
The only MPEG-2 encoder that allows anthing closest to this feature,
is TMPGenc. It will allow you to change any I, P, B parameter as you
see fit, and it will apply the new setting throughout your video during
the encoding phase.
However, if you want to go further than this, "specifically" on a range
of frames, then you would have
How to:
** Settings button
** Video tab, change Rate control mode: [ Manual VBR (MVBR) ]
** GOP structure tab (note the I, P, B fields)
** [x] force picture type setting, click [settings] button
Once inside this "alice 'n wonderland" you are on your own as far as what
settings/params you desire to change. I have visited this area a few
times.. [to change bitrates for black areas to specific bitrates, and a
few other settings].. Its a chore to manage.. believe me.. its not user-friendly.
IMPORTANT - in order to activate this feature, you must be in
Manual VBR (MVBR) mode (see above) otherwise you will be pulling your
hair out to no avail, wondering why its not working.
Also, some tools to recommend in aiding with this procedure:
** vdubMOD / virtualDubMOD - used to observe changes in I, P, and B frames (statusline)
** (bitrate viewer) BV - a bitrate analyising (graph) tool to observe bitrate, etc.
** MPEG Validator - displays GOP structure and bitrate per GOP.
-vhelp 3973 -
TMPGEnc can import a list of I Frames from a file. Useful when you want to re-encode a file with a predicted structure (e.g. for producing an MPEG-2 stream to replace an existing video stream from a DVD where chapters are already defined).
The B and P frames are subsequently defined by the I/P/B structure in the B/P ratio and generally there are no apps that allow such fine tuning.
I would suggest you experiment with TMPGENC first to see if the flexibility it offers suits you.The more I learn, the more I come to realize how little it is I know. -
Originally Posted by vhelp
There's also MPEG-2 Validator to display the GOP structure and bitrate per GOP.
tools section though.
-vhelp 3974 -
@ Abond
Ahh, got itolyteddy had the -2 in there, causing missfire in link.
Thanks!
-vhelp 3975
decoding mpeg video into frames say I,P,B frames
By abeer in forum ProgrammingReplies: 44Last Post: 6th Oct 2012, 08:24 -
which is better Mainconcept MPEG Encoder or H.254 Encoder
By d_unbeliever in forum Newbie / General discussionsReplies: 7Last Post: 4th Aug 2012, 18:14 -
1080i 29.97 frames/sec to DVD compliant SD using Avisynth and HC encoder
By johnnyquid in forum Video ConversionReplies: 2Last Post: 25th Jul 2011, 15:24 -
I-frames in MPEG-2
By DRP in forum Newbie / General discussionsReplies: 2Last Post: 3rd Aug 2008, 22:48 -
Menus buttons become assigned to wrong episodes/files
By messiahVx02 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 31st Jan 2008, 02:40
