I just got a dvd burner tonight and i have 30gb of .avi and .vob files i want to turn into a standalone dvd playable dvd and I just dont know where to start and what the best programs are to use.. anyone help me plz?
There's a big difference with VOB files and AVI files. For AVI, you need to encode them to DVD compatible video. See 'What is' DVD to see the DVD format.
There are lots of way to encode to MPEG-2. I use TMPGEnc encoder most of the time. But whatever you use, you need to get to DVD compliant video. There are freeware encoders also.
Then when you have encoded the video and audio, you need to author it to DVD specs. I use TMPGEnc DVD Author, but there are a few freeware authoring programs available.
If you look to the left, under 'HOW TO' you will see our guides. It depends on the software you have for what process you can use. Do a little exploring.
If you have VOB files, then they should already be DVD compatible. All you have to do then is to burn them. If you have only VOBs and not the rest of the DVD structure, you can use IFOEdit to restore the other parts.
Sorry, there is no 'does it all' tutorial. You just have to read and experiment.
If you want to get started quickly, convertxtodvd is for you. Just load and go. Otherwise, all you need to know is over to your left
Start with the How To section, then look at the tutorial list associuated with the tools you have. Finally, come back and ask questions.
There really is no definative go to woe guide, as there are many, many tools, and many, many methods. And no guide covers all the contingencies either.Read my blog here.
So for the vobs . how can i tell if I have the COMPLETE dvd structure.. i know it has a menu already and stuff ? also the place i downloaded this dvd rip from I was reading the torrent details and there was something about running it thru dvd shrink to fix some burning problem.. and a friend told me I had to author the dvd or something before it will play in my standalone players.
Again, 'What is' DVD will tell you the DVD spec. You only have to read it.
https://www.videohelp.com/guides.php?tools=&madeby=&formatconversionselect=AVI+to+DVD&h...or+List+Guides
That should help.
Thanks Mike
Start Tracks for new type of encrypted DVD's - Running list
By Groty in forum DVD RippingReplies: 8Last Post: 27th Dec 2009, 21:04 -
NOT finish DVD
By black lion in forum Newbie / General discussionsReplies: 3Last Post: 18th Feb 2009, 18:40 -
Nero 7.7.5.1 start burning at 1x!?
By arminio in forum Authoring (DVD)Replies: 23Last Post: 5th Jan 2009, 05:50 -
Error I get after I finish copying a dvd with copytodvd
By litzg5 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 8th Feb 2008, 14:17 -
DVD burner won't finish burn
By JDShaffer in forum DVD & Blu-ray WritersReplies: 6Last Post: 15th Jul 2007, 20:41
