I have an avi that is pal which is 25fps and I am going to convert it to ntsc 23.976fps. I also have the subtitles for this avi and I am going to add them using submux tool from vobsub. Do I need to mux the subtitles first and then using vdub to change the framerate of the avi or is there a tool to change the frame rate of the subtitles. I am planning on muxing the subtitles and then using direct stream copy to save the file in vdub after changing the framerate. Will this work?
Newbie question about frame rates.
By MrTorso in forum Video ConversionReplies: 4Last Post: 13th Jul 2011, 23:49 -
Help Aspect Ratios & Frame Rates
By CTP-Crystal in forum Newbie / General discussionsReplies: 21Last Post: 1st May 2009, 19:10 -
Question about Blu-ray frame rates
By Mentasm in forum Authoring (Blu-ray)Replies: 2Last Post: 26th Sep 2008, 12:16 -
Virtuadub shows two different frame rates ?
By vodmare in forum Video ConversionReplies: 8Last Post: 12th May 2008, 19:47 -
Encoding in Virtualdub: Do you have to worry about frame rates?
By FallenAngelII in forum Newbie / General discussionsReplies: 28Last Post: 7th May 2007, 12:15
