Hi Guys, Help!
I've got a "Celera DVD3600" home theatre in a box. I would like to put its functions on a universial remote. I cannot find the codes! The mfg's web site does not work for me, also I've tried to phone numerous times at all hours, I only get a busy signal. So Help!
Thanks & Take Care
rico
If I felt any better, Id be sick!
Wooow... never heard of that brand.. and no luck on my usual sites.
But don't give up hope....
IF you have an One for All (OFA) remote:
LINKIf you need to mail in a remote to OFA to have an upgrade added, you need to call first to tell them what codes you're looking for. They will then give you a tag number and tell you what address to mail the remote to. They do not charge for this service and they even pay for the return postage.
The upgrade phone number is: (330) 405 8616
The mail-in address is:
"One For All"
1864 Enterprise Parkway
Twinsburg, OH 44087
Attn: Upgrade Dept
OR
If you have a JP1 remote the sky is the limit. (There is a bit of a learning cure for JP1... but it is awsome to have your remote setup just how you want it.)
Good Luck,
JSBIt will be very hard to defend your rights, when you don't have any. -
Wow! The model number got all screwed up in my first post it should be:
Celera DVD3600
ricoIf I felt any better, Id be sick! -
It's been awhile, but I thought that there is a way to do like a semi auto search with a One for All remote. Check the manual, I haven't done it for a few years but there is a way to keep scrolling thru like the on off until your device works and then drill down until you get most if not all of the functions to work. Been there, done that, but the booklet is long gone or buried too deep to find in my mess.
IS IT SUPPOSED TO SMOKE LIKE THAT?
Remote control of computer?
By cwb in forum Media Center PC / MediaCentersReplies: 9Last Post: 29th May 2010, 18:29 -
Need Remote control code for Desay DEVD player 5701 bought at Radio Shack
By PunkMaister in forum DVD & Blu-ray PlayersReplies: 0Last Post: 15th Aug 2009, 19:20 -
ATI remote control
By lazybum in forum Capturing and VCRReplies: 2Last Post: 12th Jun 2009, 17:19 -
Remote control for VBox?
By slytrans69 in forum Media Center PC / MediaCentersReplies: 0Last Post: 15th Aug 2008, 15:53 -
Have you got a SKYWORTH 3650 DIVX player or programable remote control code
By mike47 in forum DVD & Blu-ray PlayersReplies: 8Last Post: 4th May 2007, 05:57
