I'm using the latest version of TMPGEnc to convert avi files to mpg to make them into vcd's. I have all of the settings correct but when it finished encoding Theres no sound in the movie. I've tried with different movies and I get the same thing. I've also tried with an older version of TMPGEnc but the same thing happens, I know I'm doing this right because it worked before on my old computer. Can somebody help me out with this?
i have had this prob on most avis i fixed it by loading the avi in to virtaldub then going back to file and save as wav then use that as the sound source instead of the avi as both do that then encode for about 10 mins to see how its going then if it looks ok and in sync just encode the whole file like that im still working on how to fix files that dont encode in sync
Sound quality of Tmpgenc: Is it that bad?
By Banleno007 in forum Video ConversionReplies: 3Last Post: 15th Feb 2012, 22:10 -
TMPGEnc DVD Author-sound?
By Mållgan in forum Authoring (DVD)Replies: 2Last Post: 14th Apr 2009, 06:51 -
Converting AVI using TMPGenc = No Sound?
By CaptainChaos in forum Video ConversionReplies: 2Last Post: 16th Dec 2008, 17:12 -
TMPGenc DVD Author 3 Sound Problems
By wapdoggie in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2007, 17:00 -
TMPGEnc Plus and AVI sound
By busdonic in forum Video ConversionReplies: 5Last Post: 22nd Jun 2007, 11:18
