    May 2006
    i was using nero 7 , but ive had nothing but trouble with that (will not burn any dvd video, but would burn data to dvd ), ive finally given up on nero sorting out there software and would like to know if there’s some other software(buy or free) i can use to do the following,
    1.must have Dolby Digital 5.1 Encoder integration
    2.convert avi’s/divx’s/wmv into dvd format,and then burn it in one process (ie i can start it and leave it on overnight)
    3.copy bought dvd’s (for backup purposes,as i tend to scratch alot of dvd's)
    4.burn data dvd’s
    5.cd audio and data burning.
    i dont care if it can make flashy menu’s , edit videos , make me a cup of tea ... ect
    i have been searching around on the net for something similar to nero7(for like over 8 hrs)but none of the sites say if they support 5.1 sound in dvd's, and most dont have an email service to ask , just expensive call centres.
    so if you use or know of any software i can use pls post and let me know.. thnx
  2. Data CDs and DVDs: Deep Burner (free)
    Copy DVDs:
    Rip: DVD Decrypter (free), DVDFab Decrypter (free)
    Shrink to DVD5: DVD Shrink (free)
    Burn: DVD Decrypter (free), ImgBurn (free)
    CD Audio burning: EAC (free), Burrrn (free)
    Convert avi/Divx/wmv/etc. to DVD: AVI2DVD (free), DivxtoDVD (free, but you should get the new pay version), D2MP (free)
    Also check out: ImgTool Classic (free)
    Hope that helps. You don't need Nero.
    Darryl
  3. check dvdfab but i don't think it does divx
    DVDFab Platinum 30 days trial
    divxtodvd simple and free
    Apr 2006
    maybe your problem with your hardware not nero.i too thought nero was the problem but then i upgraded my firmware for my burner and then it works.
    May 2006
    its deffenatly nero 7, i went to the trouble of making sure all parts of my pc had latest drivers firmware and bios , then did a complete reinstall of windows , put all drivers and updates on and just nero 7 and i still had the fault with nerovision. as nero tried to convince me i had a conflict with some other software. here's a fail log of a file i tried to convert on to my hardrive..
    note this is off of a fresh reinstall, all i did was drop the file into nerovision and turn off menu.and selected the output file to go on my hardrive not a blank dvd.no other options were changed.
    [22:22:21] NeroVision Log created (Date: 06/02/2006)
    [22:23:14] NeroVision Processors: 1 (Intel)
    [22:23:14] NeroVision OS: Windows XP
    [22:23:18] GCCore Detected DirectX Version: 9.0c
    [22:23:23] ExpressUI Running Nero Vision Version: 4.5.0.15
    [22:23:24] DVDEngine C:\PROGRAM FILES\NERO\NERO 7\NERO VISION\DVDENGINE.DLL
    [22:23:24] DVDEngine Product Version: 4.5.0.3, File Version: 4.5.0.35, Interface Version: 4.5.0.0
    [22:23:24] DVDEngine BEGIN: IDVDEngineManagerImpl - CreateDVDVideoSession
    [22:23:24] DVDEngine END: IDVDEngineManagerImpl - CreateDVDVideoSession
    [22:23:24] DVDEngine BEGIN: IDVDSessionBaseImpl - RegisterApplicationService
    [22:23:24] DVDEngine ..Application service registered...
    [22:23:24] DVDEngine END: IDVDSessionBaseImpl - RegisterApplicationService
    [22:23:26] MMTools SourceBuilder: building c:\Documents and Settings\DjSuicide\Desktop\my mix @ club.avi audio/0
    [22:23:26] MMTools SourceBuilder: --- used source filters ---
    [22:23:26] MMTools {E436EBB5-524F-11CE-9F53-0020AF0BA770} - File Source (Async.)
    [22:23:26] MMTools {1B544C20-FD0B-11CE-8C63-00AA0044B51E} - AVI Splitter
    [22:23:26] MMTools {38BE3000-DBF4-11D0-860E-00A024CFEF6D} - MPEG Layer-3 Decoder
    [22:23:26] MMTools SourceBuilder: file type AVI - audio
    [22:23:26] MMTools --------------------
    [22:23:26] MMTools SourceBuilder: building c:\Documents and Settings\DjSuicide\Desktop\my mix @ club.avi video/0
    [22:23:27] MMTools SourceBuilder: --- used source filters ---
    [22:23:27] MMTools {E436EBB5-524F-11CE-9F53-0020AF0BA770} - File Source (Async.)
    [22:23:27] MMTools {1B544C20-FD0B-11CE-8C63-00AA0044B51E} - AVI Splitter
    [22:23:27] MMTools {C0BA9CF8-96E0-4C34-B5DE-E92C3FC05ED6} - Nero Video Decoder
    [22:23:27] MMTools SourceBuilder: file type AVI - video
    [22:23:27] MMTools --------------------
    [22:23:27] AMCUIBase Asset created by user: class AVFileAsset
    [22:23:27] AMCUIBase - file paths: 1, first = 'c:\Documents and Settings\DjSuicide\Desktop\my mix @ club.avi')
    [22:23:27] DVDEngine BEGIN: IDVDSessionBaseImpl - RegisterCallback
    [22:23:27] DVDEngine END: IDVDSessionBaseImpl - RegisterCallback
    [22:23:27] DVDEngine BEGIN: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
    [22:23:27] DVDEngine END: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
    [22:23:28] DVDEngine C:\PROGRAM FILES\NERO\NERO 7\NERO VISION\DVDENGINE.DLL
    [22:23:28] DVDEngine Product Version: 4.5.0.3, File Version: 4.5.0.35, Interface Version: 4.5.0.0
    [22:23:28] DVDEngine BEGIN: IDVDEngineManagerImpl - CreateDVDVideoSession
    [22:23:28] DVDEngine END: IDVDEngineManagerImpl - CreateDVDVideoSession
    [22:23:28] DVDEngine BEGIN: IDVDSessionBaseImpl - RegisterApplicationService
    [22:23:28] DVDEngine ..Application service registered...
    [22:23:28] DVDEngine END: IDVDSessionBaseImpl - RegisterApplicationService
    [22:23:28] NeroVision Estimate Size
    [22:23:28] NeroVision +-------+------+--------+----------+---------
    [22:23:28] NeroVision |Stream | Seg. | UnComp.| Duration | Size (KB)
    [22:23:28] NeroVision | 0 | 0 | 1 | 0.04 | 224
    [22:23:28] NeroVision | 1 | 0 | 0 | 0.04 | 0
    [22:23:28] NeroVision total data size : 458753 bytes
    [22:23:28] NeroVision multiplexed size : 475136 bytes
    [22:23:28] NeroVision | 0 | 0 | 1 | 5553.92 | 3439559
    [22:23:28] NeroVision | 1 | 0 | 1 | 5553.92 | 311020
    [22:23:28] NeroVision total data size : 3840822260 bytes
    [22:23:28] NeroVision multiplexed size : 3966416896 bytes
    [22:23:28] MMTools SourceBuilder: building cached c:\Documents and Settings\DjSuicide\Desktop\my mix @ club.avi video/0
    [22:23:38] MMTools BitmapGrabber::InternalGetBitmap - failed to get sample (timeout)
    [22:23:38] MMTools BitmapGrabber::InternalGetBitmap - error handler (begin stop graph)
    [22:23:38] MMTools BitmapGrabber::InternalGetBitmap - error handler (end stop graph)
    [22:26:02] DVDEngine BEGIN: IDVDSessionBaseImpl - RegisterCallback
    [22:26:02] DVDEngine END: IDVDSessionBaseImpl - RegisterCallback
    [22:26:02] DVDEngine BEGIN: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
    [22:26:02] DVDEngine END: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
    [22:26:02] DVDEngine C:\PROGRAM FILES\NERO\NERO 7\NERO VISION\DVDENGINE.DLL
    [22:26:02] DVDEngine Product Version: 4.5.0.3, File Version: 4.5.0.35, Interface Version: 4.5.0.0
    [22:26:02] DVDEngine BEGIN: IDVDEngineManagerImpl - CreateDVDVideoSession
    [22:26:02] DVDEngine END: IDVDEngineManagerImpl - CreateDVDVideoSession
    [22:26:02] DVDEngine BEGIN: IDVDSessionBaseImpl - RegisterApplicationService
    [22:26:02] DVDEngine ..Application service registered...
    [22:26:02] DVDEngine END: IDVDSessionBaseImpl - RegisterApplicationService
    [22:26:02] NeroVision Estimate Size
    [22:26:02] NeroVision +-------+------+--------+----------+---------
    [22:26:02] NeroVision |Stream | Seg. | UnComp.| Duration | Size (KB)
    [22:26:02] NeroVision | 0 | 0 | 1 | 5553.92 | 3439559
    [22:26:02] NeroVision | 1 | 0 | 1 | 5553.92 | 311020
    [22:26:02] NeroVision total data size : 3840822260 bytes
    [22:26:02] NeroVision multiplexed size : 3966416896 bytes
    [22:26:04] MMTools SourceBuilder: building cached c:\Documents and Settings\DjSuicide\Desktop\my mix @ club.avi audio/0
    [22:26:04] MMTools SourceBuilder: building cached c:\Documents and Settings\DjSuicide\Desktop\my mix @ club.avi video/0
    [22:33:43] MMTools SourceBuilder: building cached c:\Documents and Settings\DjSuicide\Desktop\my mix @ club.avi audio/0
    [22:33:44] MMTools SourceBuilder: building cached c:\Documents and Settings\DjSuicide\Desktop\my mix @ club.avi video/0
    [22:33:47] DVDEngine BEGIN: IDVDSessionBaseImpl - RegisterCallback
    [22:33:47] DVDEngine END: IDVDSessionBaseImpl - RegisterCallback
    [22:33:47] DVDEngine BEGIN: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
    [22:33:47] DVDEngine END: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
    [22:33:47] DVDEngine C:\PROGRAM FILES\NERO\NERO 7\NERO VISION\DVDENGINE.DLL
    [22:33:47] DVDEngine Product Version: 4.5.0.3, File Version: 4.5.0.35, Interface Version: 4.5.0.0
    [22:33:47] DVDEngine BEGIN: IDVDEngineManagerImpl - CreateDVDVideoSession
    [22:33:47] DVDEngine END: IDVDEngineManagerImpl - CreateDVDVideoSession
    [22:33:47] DVDEngine BEGIN: IDVDSessionBaseImpl - RegisterApplicationService
    [22:33:47] DVDEngine ..Application service registered...
    [22:33:47] DVDEngine END: IDVDSessionBaseImpl - RegisterApplicationService
    [22:33:55] MMTools SourceBuilder: building c:\Documents and Settings\DjSuicide\My Documents\My Videos\American Dad Season 1 Episode 1-19\American Dad - 101 - Pilot.avi audio/0
    [22:33:56] MMTools SourceBuilder: failed to build c:\Documents and Settings\DjSuicide\My Documents\My Videos\American Dad Season 1 Episode 1-19\American Dad - 101 - Pilot.avi audio: 0x8004025d -
    [22:33:56] MMTools SourceBuilder: building c:\Documents and Settings\DjSuicide\My Documents\My Videos\American Dad Season 1 Episode 1-19\American Dad - 101 - Pilot.avi video/0
    [22:33:56] MMTools SourceBuilder: failed to build c:\Documents and Settings\DjSuicide\My Documents\My Videos\American Dad Season 1 Episode 1-19\American Dad - 101 - Pilot.avi video: 0x8004025d -
    [22:34:27] MMTools SourceBuilder: building c:\Documents and Settings\DjSuicide\Desktop\American Dad - 119 - It's Good to be the Queen.avi audio/0
    [22:34:28] MMTools SourceBuilder: failed to build c:\Documents and Settings\DjSuicide\Desktop\American Dad - 119 - It's Good to be the Queen.avi audio: 0x8004025d -
    [22:34:28] MMTools SourceBuilder: building c:\Documents and Settings\DjSuicide\Desktop\American Dad - 119 - It's Good to be the Queen.avi video/0
    [22:34:28] MMTools SourceBuilder: failed to build c:\Documents and Settings\DjSuicide\Desktop\American Dad - 119 - It's Good to be the Queen.avi video: 0x8004025d -
    [22:34:41] AMCUIBase Asset created by user: class AVFileAsset
    [22:34:41] AMCUIBase - file paths: 1, first = 'c:\Documents and Settings\DjSuicide\Desktop\my mix @ club.avi')
    [22:34:41] DVDEngine BEGIN: IDVDSessionBaseImpl - RegisterCallback
    [22:34:41] DVDEngine END: IDVDSessionBaseImpl - RegisterCallback
    [22:34:41] DVDEngine BEGIN: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
    [22:34:41] DVDEngine END: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
    [22:34:41] DVDEngine C:\PROGRAM FILES\NERO\NERO 7\NERO VISION\DVDENGINE.DLL
    [22:34:41] DVDEngine Product Version: 4.5.0.3, File Version: 4.5.0.35, Interface Version: 4.5.0.0
    [22:34:41] DVDEngine BEGIN: IDVDEngineManagerImpl - CreateDVDVideoSession
    [22:34:41] DVDEngine END: IDVDEngineManagerImpl - CreateDVDVideoSession
    [22:34:41] DVDEngine BEGIN: IDVDSessionBaseImpl - RegisterApplicationService
    [22:34:41] DVDEngine ..Application service registered...
    [22:34:41] DVDEngine END: IDVDSessionBaseImpl - RegisterApplicationService
    [22:34:41] NeroVision Estimate Size
    [22:34:41] NeroVision +-------+------+--------+----------+---------
    [22:34:41] NeroVision |Stream | Seg. | UnComp.| Duration | Size (KB)
    [22:34:41] NeroVision | 0 | 0 | 1 | 5553.92 | 3439559
    [22:34:41] NeroVision | 1 | 0 | 1 | 5553.92 | 311020
    [22:34:41] NeroVision total data size : 3840822260 bytes
    [22:34:41] NeroVision multiplexed size : 3966416896 bytes
    [22:34:41] MMTools SourceBuilder: building cached c:\Documents and Settings\DjSuicide\Desktop\my mix @ club.avi video/0
    [22:34:51] MMTools BitmapGrabber::InternalGetBitmap - failed to get sample (timeout)
    [22:34:51] MMTools BitmapGrabber::InternalGetBitmap - error handler (begin stop graph)
    [22:34:51] MMTools BitmapGrabber::InternalGetBitmap - error handler (end stop graph)
    [22:35:20] DVDEngine BEGIN: IDVDSessionBaseImpl - RegisterCallback
    [22:35:20] DVDEngine END: IDVDSessionBaseImpl - RegisterCallback
    [22:35:20] DVDEngine BEGIN: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
    [22:35:20] DVDEngine END: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
    [22:35:20] DVDEngine C:\PROGRAM FILES\NERO\NERO 7\NERO VISION\DVDENGINE.DLL
    [22:35:20] DVDEngine Product Version: 4.5.0.3, File Version: 4.5.0.35, Interface Version: 4.5.0.0
    [22:35:20] DVDEngine BEGIN: IDVDEngineManagerImpl - CreateDVDVideoSession
    [22:35:20] DVDEngine END: IDVDEngineManagerImpl - CreateDVDVideoSession
    [22:35:20] DVDEngine BEGIN: IDVDSessionBaseImpl - RegisterApplicationService
    [22:35:20] DVDEngine ..Application service registered...
    [22:35:20] DVDEngine END: IDVDSessionBaseImpl - RegisterApplicationService
    [22:35:20] NeroVision Estimate Size
    [22:35:20] NeroVision +-------+------+--------+----------+---------
    [22:35:20] NeroVision |Stream | Seg. | UnComp.| Duration | Size (KB)
    [22:35:20] NeroVision | 0 | 0 | 1 | 5553.92 | 3439559
    [22:35:20] NeroVision | 1 | 0 | 1 | 5553.92 | 311020
    [22:35:20] NeroVision total data size : 3840822260 bytes
    [22:35:20] NeroVision multiplexed size : 3966416896 bytes
    [22:35:28] MMTools SourceBuilder: building cached c:\Documents and Settings\DjSuicide\Desktop\my mix @ club.avi audio/0
    [22:35:28] MMTools SourceBuilder: building cached c:\Documents and Settings\DjSuicide\Desktop\my mix @ club.avi video/0
    [22:35:51] ExpressUI Burn process started by user.
    [22:35:51] ExpressUI Destination: C:\Documents and Settings\DjSuicide\Desktop
    [22:35:51] ExpressUI Directory for temporary files: C:\DOCUME~1\DJSUIC~1\LOCALS~1\Temp
    [22:35:51] ExpressUI Available hard disk space for temporary files: 72337.883 MB
    [22:35:51] ExpressUI ------<Nero Vision Project Information>--------
    [22:35:51] ExpressUI --- Project type: DVD-Video
    [22:35:51] ExpressUI --- Project video options ---
    [22:35:51] ExpressUI Video mode: PAL
    [22:35:51] ExpressUI Aspect ratio: Automatic
    [22:35:51] ExpressUI Quality: Standard play (5073 kbit/s)
    [22:35:51] ExpressUI Resolution: 720 x 576 (CCIR-601 D1)
    [22:35:51] ExpressUI Sample format: Automatic
    [22:35:51] ExpressUI Video format: MPEG-2
    [22:35:51] ExpressUI Audio format: Dolby Digital (AC-3) 5.1
    [22:35:51] ExpressUI Encoding mode: High Quality (2-Pass VBR)
    [22:35:51] ExpressUI Nero SmartEncoding: Enable
    [22:35:51] ExpressUI --- Project space information ---
    [22:35:51] ExpressUI Media type: DVD (4700000000 bytes maximum capacity)
    [22:35:51] ExpressUI Total space used: 3.70 out of 4.38 GB
    [22:35:51] ExpressUI Space used for menus: 0.0 out of 1024.0 MB
    [22:35:51] ExpressUI --- Project contents ---
    [22:35:51] ExpressUI Number of titles: 1
    [22:35:51] ExpressUI 1. my mix @ club (Video Title, 1h 32m 33s)
    [22:35:51] ExpressUI - Audio SmartEncoding ratio: 0.0 %
    [22:35:51] ExpressUI - Video SmartEncoding ratio: 0.0 %
    [22:35:51] ExpressUI --------<End of Project Information>----------
    [22:35:51] ExpressUI ------Recording Parameters------
    [22:35:51] ExpressUI Book Type: 1
    [22:35:51] ExpressUI Destination Device: ASUS DRW-1608P (Capabilities: 000AC117)
    [22:35:51] ExpressUI Recording Flags: 12
    [22:35:51] ExpressUI Recording Speed: 0
    [22:35:51] ExpressUI Volume Name: DVD
    [22:35:51] ExpressUI Burn-at-once flag: 0
    [22:35:51] ExpressUI Fast Update allowed: 0
    [22:35:51] ExpressUI --End of recording parameters---
    [22:35:52] DVDEngine C:\PROGRAM FILES\NERO\NERO 7\NERO VISION\DVDENGINE.DLL
    [22:35:52] DVDEngine Product Version: 4.5.0.3, File Version: 4.5.0.35, Interface Version: 4.5.0.0
    [22:35:52] DVDEngine BEGIN: IDVDEngineManagerImpl - CreateDVDVideoSession
    [22:35:52] DVDEngine END: IDVDEngineManagerImpl - CreateDVDVideoSession
    [22:35:52] DVDEngine BEGIN: IDVDSessionBaseImpl - RegisterApplicationService
    [22:35:52] DVDEngine ..Application service registered...
    [22:35:52] DVDEngine END: IDVDSessionBaseImpl - RegisterApplicationService
    [22:35:52] DVDEngine BEGIN: IDVDSessionBaseImpl - RegisterCallback
    [22:35:52] DVDEngine ..Session callback registered...
    [22:35:52] DVDEngine END: IDVDSessionBaseImpl - RegisterCallback
    [22:35:52] DVDEngine BEGIN: IDVDVideoSessionImpl - Prepare
    [22:35:52] DVDEngine **BEGIN: _DVDVideo - Prepare
    [22:35:52] DVDEngine ..VTS_Ns=1...
    [22:35:52] DVDEngine ****BEGIN: _DVDVideoBase - Prepare VMG
    [22:35:52] DVDEngine ...VMGM_VOBS_exist = false
    [22:35:52] DVDEngine ****END: _DVDVideoBase - Prepare VMG
    [22:35:52] DVDEngine ****BEGIN: _DVDVideoBase - Prepare VTS#1
    [22:35:52] DVDEngine ...VTSM_VOBS_exist = false
    [22:35:52] DVDEngine ******BEGIN: VTSTT_VOBS#1 - Process Create
    [22:35:52] DVDEngine ********BEGIN: _VOBS - Process VOB
    [22:35:52] DVDEngine **********BEGIN: _VOBS - _M_analyze_cnv_input
    [22:35:52] DVDEngine ...Duration 55539200000
    [22:35:52] DVDEngine ..._streamtime_frame_duration is 400000
    [22:35:52] DVDEngine ...Stream 0 is 'Video'
    [22:35:52] DVDEngine ...Stream 1 is 'Audio'
    [22:35:52] DVDEngine **********END: _VOBS - _M_analyze_cnv_input
    [22:35:52] NeroVision Analyze video stream
    [22:35:52] NeroVision Seg. | frames | weight | volume
    [22:35:52] NeroVision ------+---------+--------+--------
    [22:35:52] NeroVision 0 | 138848 | 2 | 277696
    [22:35:52] NeroVision total : 277696
    [22:35:52] NeroVision Estimate Size
    [22:35:52] NeroVision +-------+------+--------+----------+---------
    [22:35:52] NeroVision |Stream | Seg. | UnComp.| Duration | Size (KB)
    [22:35:52] NeroVision | 0 | 0 | 1 | 5553.92 | 3439559
    [22:35:52] NeroVision | 1 | 0 | 1 | 5553.92 | 311020
    [22:35:52] NeroVision total data size : 3840822260 bytes
    [22:35:52] NeroVision multiplexed size : 3966416896 bytes
    [22:35:52] MMTools SourceBuilder: building cached c:\Documents and Settings\DjSuicide\Desktop\my mix @ club.avi video/0
    [22:35:55] MMTools SourceBuilder: building cached c:\Documents and Settings\DjSuicide\Desktop\my mix @ club.avi audio/0
    [22:35:56] DVDEngine ********END: _VOBS - Process VOB
    [22:35:56] DVDEngine ******END: VTSTT_VOBS#1 - Process Create
    [22:35:56] DVDEngine ****END: _DVDVideoBase - Prepare VTS#1
    [22:35:56] DVDEngine **END: _DVDVideo - Prepare
    [22:35:56] DVDEngine ..Estimated size=3.69 GB
    [22:35:56] DVDEngine ..Estimated duration=1 hour 59 min 30 sec
    [22:35:56] DVDEngine END: IDVDVideoSessionImpl - Prepare
    [22:35:56] DVDEngine BEGIN: IDVDVideoSessionImpl - CreateVOBs
    [22:35:56] DVDEngine **BEGIN: _DVDVideo - Create
    [22:35:56] DVDEngine ****BEGIN: Create - VTSTT_VOBS#1
    [22:35:56] DVDEngine ******BEGIN: VTSTT_VOBS#1 - Process Create
    [22:35:56] DVDEngine ********BEGIN: _VOBS - Process VOB
    [22:35:56] DVDEngine **********BEGIN: _VOBS - _M_analyze_cnv_input
    [22:35:56] DVDEngine ...Duration 55539200000
    [22:35:56] DVDEngine ..._streamtime_frame_duration is 400000
    [22:35:56] DVDEngine ...Stream 0 is 'Video'
    [22:35:56] DVDEngine ...Stream 1 is 'Audio'
    [22:35:56] DVDEngine **********END: _VOBS - _M_analyze_cnv_input
    [22:35:56] NeroVision Analyze video stream
    [22:35:56] NeroVision Seg. | frames | weight | volume
    [22:35:56] NeroVision ------+---------+--------+--------
    [22:35:56] NeroVision 0 | 138848 | 2 | 277696
    [22:35:56] NeroVision total : 277696
    [22:35:56] NeroVision Estimate Size
    [22:35:56] NeroVision +-------+------+--------+----------+---------
    [22:35:56] NeroVision |Stream | Seg. | UnComp.| Duration | Size (KB)
    [22:35:56] NeroVision | 0 | 0 | 1 | 5553.92 | 3439559
    [22:35:56] NeroVision | 1 | 0 | 1 | 5553.92 | 311020
    [22:35:56] NeroVision total data size : 3840822260 bytes
    [22:35:56] NeroVision multiplexed size : 3966416896 bytes
    [22:35:56] DVDEngine ...estimated VOB size is 1936736 sectors (3.69 GB).
    [22:35:56] NeroVision Set Preview Channel
    [22:35:56] MMTools SourceBuilder: building cached c:\Documents and Settings\DjSuicide\Desktop\my mix @ club.avi audio/0
    [22:35:56] MMTools SourceBuilder: building cached c:\Documents and Settings\DjSuicide\Desktop\my mix @ club.avi video/0
    [23:22:54] DVDEngine ...New VOB 1
    [23:22:54] DVDEngine ..+VOB#1: VOB_IDN=1, SA=0, VOB_V_S_PTM=27124
    [23:22:54] DVDEngine ...New CELL 1
    [23:22:54] DVDEngine ....+Cell#1: C_IDN=1
    [23:23:51] DVDEngine ********END: _VOBS - Process VOB
    [23:23:51] DVDEngine ******END: VTSTT_VOBS#1 - Process Create
    [23:23:51] DVDEngine ****END: Create - VTSTT_VOBS#1
    [23:23:51] DVDEngine **END: _DVDVideo - Create
    [23:23:51] DVDEngine ################################################## ######################################
    [23:23:51] DVDEngine ERROR
    [23:23:51] DVDEngine cause: 128 (nmc_processing_exception)
    [23:23:51] DVDEngine source: CDVDProcessor::ProcessSector
    [23:23:51] DVDEngine description: buffer overflow
    [23:23:51] DVDEngine END: IDVDVideoSessionImpl - CreateVOBs
    [23:23:51] DVDEngine BEGIN: IDVDSessionBaseImpl - RegisterCallback
    [23:23:51] DVDEngine ..Session callback unregistered...
    [23:23:51] DVDEngine END: IDVDSessionBaseImpl - RegisterCallback
    [23:23:51] DVDEngine BEGIN: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
    [23:23:51] DVDEngine END: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
    [23:23:51] NeroVision Process information:
    [23:23:51] NeroVision --------------------
    [23:23:51] NeroVision Address Version Module name
    [23:23:51] NeroVision -----------------------------------------------------
    [23:23:51] NeroVision 0x00330000 4.5.0.15 C:\Program Files\Nero\Nero 7\Nero Vision\GCCore.dll
    [23:23:51] NeroVision 0x003C0000 4.5.0.15 C:\Program Files\Nero\Nero 7\Nero Vision\AMCDOM.dll
    [23:23:51] NeroVision 0x003D0000 4.5.0.15 C:\Program Files\Nero\Nero 7\Nero Vision\GDIPainter.dll
    [23:23:51] NeroVision 0x00400000 4.5.0.15 C:\Program Files\Nero\Nero 7\Nero Vision\NeroVision.exe
    [23:23:51] NeroVision 0x00450000 4.5.0.15 C:\Program Files\Nero\Nero 7\Nero Vision\GCLib.dll
    [23:23:51] NeroVision 0x004E0000 4.5.0.15 C:\Program Files\Nero\Nero 7\Nero Vision\AMCDocBase.dll
    [23:23:51] NeroVision 0x006D0000 4.5.0.15 C:\Program Files\Nero\Nero 7\Nero Vision\MMTools.dll
    [23:23:51] NeroVision 0x00740000 4.5.0.15 C:\Program Files\Nero\Nero 7\Nero Vision\AMCUIBase.dll
    [23:23:51] NeroVision 0x00970000 4.5.0.15 C:\Program Files\Nero\Nero 7\Nero Vision\AMCLib.dll
    [23:23:51] NeroVision 0x01190000 7.0.46.0 C:\WINDOWS\system32\ImagXpr7.dll
    [23:23:51] NeroVision 0x01210000 7.0.46.0 C:\WINDOWS\system32\ImagX7.dll
    [23:23:51] NeroVision 0x013D0000 7.0.476.0 C:\WINDOWS\system32\ImagXR7.dll
    [23:23:51] NeroVision 0x01780000 3.10.0.5900 C:\Program Files\Common Files\Ahead\Lib\AdvrCntr2.dll
    [23:23:51] NeroVision 0x01C30000 2.3.10.0 C:\Program Files\Common Files\Ahead\Lib\ShellManager.dll
    [23:23:51] NeroVision 0x01DF0000 4.5.0.15 C:\Program Files\Nero\Nero 7\Nero Vision\GCFX.DLL
    [23:23:51] NeroVision 0x02040000 1.1.0.865 C:\Program Files\Nero\Nero 7\Nero Vision\NeVideoFX.dll
    [23:23:51] NeroVision 0x022C0000 1.0.0.3 C:\Program Files\Nero\Nero 7\Nero Vision\NeVideoFX.bitmaps
    [23:23:51] NeroVision 0x02CB0000 1.2.0.6 C:\Program Files\Common Files\Ahead\Lib\NeroFileDialog.dll
    [23:23:51] NeroVision 0x02E00000 2.1.5.0 C:\Program Files\Nero\Nero 7\Nero Vision\NeroMediaCon.DLL
    [23:23:51] NeroVision 0x02F00000 4.0.1.7 C:\Program Files\Common Files\Ahead\Lib\GCHW.dll
    [23:23:51] NeroVision 0x03280000 7.2.0.3 C:\Program Files\Nero\Nero 7\Core\CDCopy.dll
    [23:23:51] NeroVision 0x032B0000 7.2.0.3 C:\Program Files\Nero\Nero 7\Core\NeroErr.dll
    [23:23:51] NeroVision 0x032D0000 7.2.0.3 C:\Program Files\Nero\Nero 7\Core\NeRSDB.dll
    [23:23:51] NeroVision 0x032E0000 1.0.0.18 C:\Program Files\Common Files\Ahead\Lib\DriveLocker.dll
    [23:23:51] NeroVision 0x05470000 4.5.0.15 C:\Program Files\Nero\Nero 7\Nero Vision\GCLocale.dll
    [23:23:51] NeroVision 0x05C10000 7.2.0.3 C:\Program Files\Nero\Nero 7\Core\NeroAPI.dll
    [23:23:51] NeroVision 0x06A10000 7.2.0.3 C:\Program Files\Nero\Nero 7\Core\CDROM.DLL
    [23:23:51] NeroVision 0x06C50000 4.5.0.15 C:\Program Files\Nero\Nero 7\Nero Vision\ExpressUI.dll
    [23:23:51] NeroVision 0x07020000 4.5.0.15 C:\Program Files\Nero\Nero 7\Nero Vision\GCHWCfg.dll
    [23:23:51] NeroVision 0x07050000 4.5.0.15 C:\Program Files\Nero\Nero 7\Nero Vision\ExpressDoc.dll
    [23:23:51] NeroVision 0x07B30000 5.2.5358.4826 C:\WINDOWS\system32\Audiodev.dll
    [23:23:51] NeroVision 0x07B80000 1.4.2.0 C:\WINDOWS\system32\btwpimif.dll
    [23:23:51] NeroVision 0x07C30000 4.5.0.15 C:\Program Files\Nero\Nero 7\Nero Vision\DVDUI.dll
    [23:23:51] NeroVision 0x07C50000 4.5.0.15 C:\Program Files\Nero\Nero 7\Nero Vision\DVDDoc.dll
    [23:23:51] NeroVision 0x07CE0000 4.5.0.15 C:\Program Files\Nero\Nero 7\Nero Vision\DVDLib.dll
    [23:23:51] NeroVision 0x080C0000 2.0.39.0 C:\WINDOWS\system32\CSH.dll
    [23:23:51] NeroVision 0x080D0000 1.1.1.0 C:\Program Files\Common Files\Ahead\DSFilter\NeResize.ax
    [23:23:51] NeroVision 0x08210000 11.0.5358.4826 C:\WINDOWS\system32\WMASF.DLL
    [23:23:51] NeroVision 0x08250000 1.4.2.0 C:\WINDOWS\system32\btosif.dll
    [23:23:51] NeroVision 0x08280000 1.2.0.6 C:\Program Files\Common Files\Ahead\Lib\NMVDS.dll
    [23:23:51] NeroVision 0x08510000 4.5.0.15 C:\Program Files\Common Files\Ahead\Lib\GCCapture.ax
    [23:23:51] NeroVision 0x08550000 4.5.0.15 C:\Program Files\Nero\Nero 7\Nero Vision\GCFilter.ax
    [23:23:51] NeroVision 0x08A50000 1.2.0.6 C:\Program Files\Common Files\Ahead\Lib\NMLogCxx.dll
    [23:23:51] NeroVision 0x08A90000 4.5.0.3 C:\Program Files\Nero\Nero 7\Nero Vision\DVDEngine.dll
    [23:23:51] NeroVision 0x08E90000 1.2.0.6 C:\Program Files\Common Files\Ahead\Lib\NMIndexStoreSvrPS.dll
    [23:23:51] NeroVision 0x08F40000 1.2.2.0 C:\Program Files\Nero\Nero 7\Nero Vision\zlib1.dll
    [23:23:51] NeroVision 0x08F60000 0.0.0.0 C:\Program Files\Nero\Nero 7\Nero Vision\lib3ds_dll.dll
    [23:23:51] NeroVision 0x09150000 0.7.0.0 C:\Program Files\Avi2Dvd\Programs\Filters\ac3filter.ax
    [23:23:51] NeroVision 0x09180000 2.0.24.0 C:\Program Files\Common Files\Ahead\DSFilter\NeVideo.ax
    [23:23:51] NeroVision 0x097B0000 1.0.0.4 C:\Program Files\Common Files\Ahead\DSFilter\NeVideoAnalyzer.ax
    [23:23:51] NeroVision 0x097E0000 5.2.5358.4826 C:\WINDOWS\system32\PortableDeviceApi.dll
    [23:23:51] NeroVision 0x098B0000 1.4.2.0 C:\WINDOWS\system32\BTNEIG~1.DLL
    [23:23:51] NeroVision 0x09980000 1.2.0.6 C:\Program Files\Common Files\Ahead\Lib\NMSearchPluginMediaLibrary.dll
    [23:23:51] NeroVision 0x09AF0000 1.0.0.80 C:\Program Files\Common Files\Ahead\DSFilter\NeroVideoProc.ax
    [23:23:51] NeroVision 0x09B30000 2.0.4.0 C:\Program Files\Common Files\Ahead\DSFilter\NeroFormatConv.ax
    [23:23:51] NeroVision 0x09B60000 1.2.6.0 C:\Program Files\Common Files\Ahead\DSFilter\NeAudioConv.ax
    [23:23:51] NeroVision 0x09B90000 3.525.1117.0 C:\WINDOWS\system32\odbcint.dll
    [23:23:51] NeroVision 0x09C50000 1.2.0.6 C:\Program Files\Common Files\Ahead\Lib\MediaLibraryNSE.dll
    [23:23:51] NeroVision 0x09CF0000 7.10.3077.0 C:\Program Files\Common Files\Ahead\Lib\MFC71U.DLL
    [23:23:51] NeroVision 0x0A200000 8.0.0.0 C:\Program Files\Common Files\Ahead\Lib\BCGCBPRO800u.dll
    [23:23:51] NeroVision 0x0A480000 11.0.5358.4826 C:\WINDOWS\system32\WMVCore.DLL
    [23:23:51] NeroVision 0x0A6E0000 1.4.2.0 C:\WINDOWS\system32\wbtapi.dll
    [23:23:51] NeroVision 0x0A7B0000 3.1.4000.2435 C:\WINDOWS\system32\msi.dll
    [23:23:51] NeroVision 0x0AB80000 1.2.0.6 C:\Program Files\Common Files\Ahead\Lib\NMSearchPluginWeb.dll
    [23:23:51] NeroVision 0x0ABC0000 1.0.0.11 C:\Program Files\Common Files\Ahead\Lib\MultiChannel.dll
    [23:23:51] NeroVision 0x0AC10000 1.4.2.0 C:\WINDOWS\system32\btrez.dll
    [23:23:51] NeroVision 0x0B300000 1.2.0.6 C:\Program Files\Common Files\Ahead\Lib\NMDataServices.dll
    [23:23:51] NeroVision 0x0B400000 1.2.0.6 C:\Program Files\Common Files\Ahead\Lib\NeroSearch.dll
    [23:23:51] NeroVision 0x0B5D0000 1.0.0.1 C:\Program Files\Common Files\Ahead\Lib\Nero3DMenuEffects.dll
    [23:23:51] NeroVision 0x0B6D0000 1.2.0.6 C:\Program Files\Common Files\Ahead\Lib\NMSearch.dll
    [23:23:51] NeroVision 0x0B720000 1.0.0.0 C:\Program Files\Common Files\Ahead\Lib\log4cxx.dll
    [23:23:51] NeroVision 0x0B7E0000 1.2.0.6 C:\Program Files\Common Files\Ahead\Lib\NMCoFoundation.dll
    [23:23:51] NeroVision 0x0B860000 0.0.0.0 C:\Program Files\Nero\Nero 7\Nero Vision\libxml2.dll
    [23:23:51] NeroVision 0x0B960000 1.8.8.0 C:\Program Files\Common Files\Ahead\DSFilter\NeSplitter.ax
    [23:23:51] NeroVision 0x0B9A0000 3.0.2.1 C:\Program Files\Nero\Nero 7\Nero Vision\NVDV.dll
    [23:23:51] NeroVision 0x0BA80000 1.9.0.0 C:\Program Files\Nero\Nero 7\Nero Vision\iconv.dll
    [23:23:51] NeroVision 0x0BC10000 5.9.9.3 C:\Program Files\Nero\Nero 7\Nero Vision\cximage.dll
    [23:23:51] NeroVision 0x0BEB0000 1.2.0.6 C:\Program Files\Common Files\Ahead\Lib\NMPluginBase.dll
    [23:23:51] NeroVision 0x10000000 7.0.0.0 C:\Program Files\Nero\Nero 7\Nero Vision\HDCC.dll
    [23:23:51] NeroVision 0x15000000 7.2.0.3 C:\Program Files\Nero\Nero 7\Core\image.dll
    [23:23:51] NeroVision 0x18000000 7.2.0.3 C:\Program Files\Nero\Nero 7\Core\ISOFS.dll
    [23:23:51] NeroVision 0x19000000 7.2.0.3 C:\Program Files\Nero\Nero 7\Core\MMC.DLL
    [23:23:51] NeroVision 0x1C400000 1.5.0.50 C:\Program Files\Avi2Dvd\Programs\Filters\l3codecx.ax
    [23:23:51] NeroVision 0x20000000 5.1.2600.2180 C:\WINDOWS\system32\xpsp2res.dll
    [23:23:51] NeroVision 0x22000000 7.2.0.3 C:\Program Files\Nero\Nero 7\Core\newtrf.dll
    [23:23:51] NeroVision 0x40000000 5.2.5358.4826 C:\WINDOWS\system32\wpdshext.dll
    [23:23:51] NeroVision 0x4D4F0000 5.1.2600.2180 C:\WINDOWS\system32\WINHTTP.dll
    [23:23:51] NeroVision 0x4EC50000 5.1.3102.2180 C:\WINDOWS\WinSxS\x86_Microsoft.Windows.GdiPlus_65 95b64144ccf1df_1.0.2600.2180_x-ww_522f9f82\gdiplus.dll
    [23:23:51] NeroVision 0x4F680000 5.3.2600.2180 C:\WINDOWS\system32\dxdiagn.dll
    [23:23:51] NeroVision 0x5AD70000 6.0.2900.2180 C:\WINDOWS\system32\UxTheme.dll
    [23:23:51] NeroVision 0x5B860000 5.1.2600.2180 C:\WINDOWS\system32\NETAPI32.dll
    [23:23:51] NeroVision 0x5ED00000 5.1.2600.2180 C:\WINDOWS\system32\OPENGL32.dll
    [23:23:51] NeroVision 0x5EDD0000 5.1.2600.2180 C:\WINDOWS\system32\OLEPRO32.DLL
    [23:23:51] NeroVision 0x60CA0000 6.5.2600.2180 C:\WINDOWS\System32\qedit.dll
    [23:23:51] NeroVision 0x662B0000 5.1.2600.2180 C:\WINDOWS\system32\hnetcfg.dll
    [23:23:51] NeroVision 0x663C0000 5.1.2600.0 C:\WINDOWS\system32\IPROP.dll
    [23:23:51] NeroVision 0x68B20000 5.1.2600.2180 C:\WINDOWS\system32\GLU32.dll
    [23:23:51] NeroVision 0x69500000 6.14.10.8421 C:\WINDOWS\system32\nvoglnt.dll
    [23:23:51] NeroVision 0x71A50000 5.1.2600.2180 C:\WINDOWS\System32\mswsock.dll
    [23:23:51] NeroVision 0x71A90000 5.1.2600.2180 C:\WINDOWS\System32\wshtcpip.dll
    [23:23:51] NeroVision 0x71AA0000 5.1.2600.2180 C:\WINDOWS\system32\WS2HELP.dll
    [23:23:51] NeroVision 0x71AB0000 5.1.2600.2180 C:\WINDOWS\system32\WS2_32.dll
    [23:23:51] NeroVision 0x71AD0000 5.1.2600.2180 C:\WINDOWS\system32\wsock32.dll
    [23:23:51] NeroVision 0x71B20000 5.1.2600.2180 C:\WINDOWS\system32\MPR.dll
    [23:23:51] NeroVision 0x71BF0000 5.1.2600.2180 C:\WINDOWS\System32\SAMLIB.dll
    [23:23:51] NeroVision 0x71C10000 5.1.2600.2180 C:\WINDOWS\System32\ntlanman.dll
    [23:23:51] NeroVision 0x71C80000 5.1.2600.2180 C:\WINDOWS\System32\NETRAP.dll
    [23:23:51] NeroVision 0x71C90000 5.1.2600.2180 C:\WINDOWS\System32\NETUI1.dll
    [23:23:51] NeroVision 0x71CD0000 5.1.2600.2180 C:\WINDOWS\System32\NETUI0.dll
    [23:23:51] NeroVision 0x722B0000 5.1.2600.2180 C:\WINDOWS\system32\sensapi.dll
    [23:23:51] NeroVision 0x72D10000 5.1.2600.0 C:\WINDOWS\system32\msacm32.drv
    [23:23:51] NeroVision 0x72D20000 5.1.2600.2180 C:\WINDOWS\system32\wdmaud.drv
    [23:23:51] NeroVision 0x73000000 5.1.2600.2180 C:\WINDOWS\system32\WINSPOOL.DRV
    [23:23:51] NeroVision 0x732E0000 5.1.2600.0 C:\WINDOWS\system32\RICHED32.DLL
    [23:23:51] NeroVision 0x736B0000 6.5.2600.2180 C:\WINDOWS\system32\msdmo.dll
    [23:23:51] NeroVision 0x73760000 5.3.2600.2180 C:\WINDOWS\system32\DDRAW.dll
    [23:23:51] NeroVision 0x73940000 5.3.2600.2180 C:\WINDOWS\system32\D3DIM700.DLL
    [23:23:51] NeroVision 0x73BC0000 5.1.2600.2180 C:\WINDOWS\system32\DCIMAN32.dll
    [23:23:51] NeroVision 0x73D70000 6.0.2900.2180 C:\WINDOWS\System32\shgina.dll
    [23:23:51] NeroVision 0x73DD0000 6.2.4.0 C:\WINDOWS\system32\MFC42.DLL
    [23:23:51] NeroVision 0x73EE0000 5.3.2600.2180 C:\WINDOWS\system32\KsUser.dll
    [23:23:51] NeroVision 0x73F10000 5.3.2600.2180 C:\WINDOWS\system32\dsound.dll
    [23:23:51] NeroVision 0x74320000 3.525.1117.0 C:\WINDOWS\system32\ODBC32.dll
    [23:23:51] NeroVision 0x74810000 6.5.2600.2749 C:\WINDOWS\system32\QUARTZ.dll
    [23:23:51] NeroVision 0x74980000 8.50.2162.0 C:\WINDOWS\System32\msxml3.dll
    [23:23:51] NeroVision 0x74AD0000 6.0.2900.2180 C:\WINDOWS\system32\POWRPROF.dll
    [23:23:51] NeroVision 0x74AE0000 5.1.2600.2180 C:\WINDOWS\system32\CFGMGR32.dll
    [23:23:51] NeroVision 0x74E30000 5.0.0.0 C:\WINDOWS\system32\RICHED20.dll
    [23:23:51] NeroVision 0x74ED0000 5.1.2600.2180 C:\WINDOWS\System32\wbem\wbemsvc.dll
    [23:23:51] NeroVision 0x74EF0000 5.1.2600.2180 C:\WINDOWS\System32\wbem\wbemprox.dll
    [23:23:51] NeroVision 0x751D0000 5.1.2600.2180 C:\WINDOWS\system32\wshbth.dll
    [23:23:51] NeroVision 0x75290000 5.1.2600.2180 C:\WINDOWS\System32\wbem\wbemcomn.dll
    [23:23:51] NeroVision 0x754D0000 5.131.2600.2180 C:\WINDOWS\system32\CRYPTUI.dll
    [23:23:51] NeroVision 0x75690000 5.1.2600.2180 C:\WINDOWS\System32\wbem\fastprox.dll
    [23:23:51] NeroVision 0x75970000 5.1.2600.2180 C:\WINDOWS\system32\MSGINA.dll
    [23:23:51] NeroVision 0x75A70000 5.1.2600.2180 C:\WINDOWS\system32\MSVFW32.dll
    [23:23:51] NeroVision 0x75F40000 6.5.2600.2180 C:\WINDOWS\System32\devenum.dll
    [23:23:51] NeroVision 0x75F60000 5.1.2600.2180 C:\WINDOWS\System32\drprov.dll
    [23:23:51] NeroVision 0x75F70000 5.1.2600.2180 C:\WINDOWS\System32\davclnt.dll
    [23:23:51] NeroVision 0x75F80000 6.0.2900.2861 C:\WINDOWS\System32\browseui.dll
    [23:23:51] NeroVision 0x76080000 6.2.3104.0 C:\WINDOWS\system32\MSVCP60.dll
    [23:23:51] NeroVision 0x76360000 5.1.2600.2180 C:\WINDOWS\system32\WINSTA.dll
    [23:23:51] NeroVision 0x76380000 5.1.2600.2180 C:\WINDOWS\system32\MSIMG32.dll
    [23:23:51] NeroVision 0x763B0000 6.0.2900.2180 C:\WINDOWS\system32\comdlg32.dll
    [23:23:51] NeroVision 0x76600000 5.1.2600.2180 C:\WINDOWS\System32\CSCDLL.dll
    [23:23:51] NeroVision 0x76780000 6.0.2900.2180 C:\WINDOWS\system32\SHFOLDER.dll
    [23:23:51] NeroVision 0x767A0000 5.1.2600.2180 C:\WINDOWS\system32\NTDSAPI.dll
    [23:23:51] NeroVision 0x76980000 5.1.2600.2751 C:\WINDOWS\system32\LINKINFO.dll
    [23:23:51] NeroVision 0x76990000 5.1.2600.2180 C:\WINDOWS\system32\ntshrui.dll
    [23:23:51] NeroVision 0x769C0000 5.1.2600.2180 C:\WINDOWS\system32\USERENV.dll
    [23:23:51] NeroVision 0x76B20000 6.5.0.2284 C:\WINDOWS\system32\ATL.DLL
    [23:23:51] NeroVision 0x76B40000 5.1.2600.2180 C:\WINDOWS\system32\WINMM.dll
    [23:23:51] NeroVision 0x76C30000 5.131.2600.2180 C:\WINDOWS\system32\WINTRUST.dll
    [23:23:51] NeroVision 0x76C90000 5.1.2600.2180 C:\WINDOWS\system32\IMAGEHLP.dll
    [23:23:51] NeroVision 0x76D60000 5.1.2600.2180 C:\WINDOWS\system32\iphlpapi.dll
    [23:23:51] NeroVision 0x76E80000 5.1.2600.2180 C:\WINDOWS\system32\rtutils.dll
    [23:23:51] NeroVision 0x76E90000 5.1.2600.2180 C:\WINDOWS\system32\rasman.dll
    [23:23:51] NeroVision 0x76EB0000 5.1.2600.2180 C:\WINDOWS\system32\TAPI32.dll
    [23:23:51] NeroVision 0x76EE0000 5.1.2600.2180 C:\WINDOWS\system32\RASAPI32.dll
    [23:23:51] NeroVision 0x76F20000 5.1.2600.2180 C:\WINDOWS\system32\DNSAPI.dll
    [23:23:51] NeroVision 0x76F60000 5.1.2600.2180 C:\WINDOWS\system32\WLDAP32.dll
    [23:23:51] NeroVision 0x76FB0000 5.1.2600.2180 C:\WINDOWS\System32\winrnr.dll
    [23:23:51] NeroVision 0x76FC0000 5.1.2600.2180 C:\WINDOWS\system32\rasadhlp.dll
    [23:23:51] NeroVision 0x76FD0000 3.0.0.4414 C:\WINDOWS\system32\CLBCATQ.DLL
    [23:23:51] NeroVision 0x77050000 3.0.0.4414 C:\WINDOWS\system32\COMRes.dll
    [23:23:51] NeroVision 0x77120000 5.1.2600.2180 C:\WINDOWS\system32\OLEAUT32.dll
    [23:23:51] NeroVision 0x771B0000 6.0.2900.2861 C:\WINDOWS\system32\WININET.dll
    [23:23:51] NeroVision 0x77260000 6.0.2900.2870 C:\WINDOWS\system32\urlmon.dll
    [23:23:51] NeroVision 0x773D0000 6.0.2900.2180 C:\WINDOWS\WinSxS\X86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.2180_x-ww_a84f1ff9\COMCTL32.dll
    [23:23:51] NeroVision 0x774E0000 5.1.2600.2726 C:\WINDOWS\system32\ole32.dll
    [23:23:51] NeroVision 0x77760000 6.0.2900.2877 C:\WINDOWS\System32\shdocvw.dll
    [23:23:51] NeroVision 0x77920000 5.1.2600.2180 C:\WINDOWS\system32\SETUPAPI.dll
    [23:23:51] NeroVision 0x77A20000 5.1.2600.2180 C:\WINDOWS\System32\cscui.dll
    [23:23:51] NeroVision 0x77A80000 5.131.2600.2180 C:\WINDOWS\system32\CRYPT32.dll
    [23:23:51] NeroVision 0x77B20000 5.1.2600.2180 C:\WINDOWS\system32\MSASN1.dll
    [23:23:51] NeroVision 0x77B40000 5.1.2600.2180 C:\WINDOWS\system32\appHelp.dll
    [23:23:51] NeroVision 0x77BD0000 5.1.2600.2180 C:\WINDOWS\system32\midimap.dll
    [23:23:51] NeroVision 0x77BE0000 5.1.2600.2180 C:\WINDOWS\system32\MSACM32.dll
    [23:23:51] NeroVision 0x77C00000 5.1.2600.2180 C:\WINDOWS\system32\VERSION.dll
    [23:23:51] NeroVision 0x77C10000 6.1.8638.2180 C:\WINDOWS\system32\msvcrt.dll
    [23:23:51] NeroVision 0x77D40000 5.1.2600.2622 C:\WINDOWS\system32\USER32.dll
    [23:23:51] NeroVision 0x77DD0000 5.1.2600.2180 C:\WINDOWS\system32\ADVAPI32.dll
    [23:23:51] NeroVision 0x77E70000 5.1.2600.2180 C:\WINDOWS\system32\RPCRT4.dll
    [23:23:51] NeroVision 0x77F10000 5.1.2600.2818 C:\WINDOWS\system32\GDI32.dll
    [23:23:51] NeroVision 0x77F60000 6.0.2900.2861 C:\WINDOWS\system32\SHLWAPI.dll
    [23:23:51] NeroVision 0x77FE0000 5.1.2600.2180 C:\WINDOWS\system32\Secur32.dll
    [23:23:51] NeroVision 0x7C140000 7.10.3077.0 C:\Program Files\Nero\Nero 7\Nero Vision\MFC71.DLL
    [23:23:51] NeroVision 0x7C340000 7.10.3052.4 C:\Program Files\Nero\Nero 7\Nero Vision\MSVCR71.dll
    [23:23:51] NeroVision 0x7C3A0000 7.10.3077.0 C:\Program Files\Nero\Nero 7\Nero Vision\MSVCP71.dll
    [23:23:51] NeroVision 0x7C800000 5.1.2600.2180 C:\WINDOWS\system32\kernel32.dll
    [23:23:51] NeroVision 0x7C900000 5.1.2600.2180 C:\WINDOWS\system32\ntdll.dll
    [23:23:51] NeroVision 0x7C9C0000 6.0.2900.2869 C:\WINDOWS\system32\SHELL32.dll
    [23:23:51] NeroVision Properties of your project:
    [23:23:51] NeroVision Video mode: PAL
    [23:23:51] NeroVision Aspect ratio: Automatic
    [23:23:51] NeroVision Quality: Standard play (5073 kbit/s)
    [23:23:51] NeroVision Media type: DVD (4700000000 bytes maximum capacity)
    [23:23:51] NeroVision Total space used: 3.70 out of 4.38 GB
    [23:23:51] NeroVision Space used for menus: 0.0 out of 1024.0 MB
    [23:23:51] NeroVision Your project contains the following:
    [23:23:51] NeroVision Audio format: Dolby Digital (AC-3) 5.1
    [23:23:51] NeroVision Sample format: Automatic
    [23:23:51] NeroVision Encoding mode: High Quality (2-Pass VBR)
    [23:23:51] NeroVision Nero SmartEncoding: Enable
    [23:23:51] NeroVision Number of titles: 1
    [23:23:51] NeroVision 1. my mix @ club (Video Title, 1h 32m 33s)
    [23:23:51] NeroVision - Audio SmartEncoding ratio: 0.0 %
    [23:23:51] NeroVision - Video SmartEncoding ratio: 0.0 %
    [23:23:51] NeroVision 1C80-80X6-19E5-MA2X-4012-0E8A-EMCM
    [23:23:51] NeroVision Windows XP 5.1
    [23:23:51] NeroVision IA32
    [23:23:51] NeroVision WinAspi: -
    [23:23:51] NeroVision ahead WinASPI: File 'C:\Program Files\Nero\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 02/11/2004 13:54:32
    [23:23:51] NeroVision NT-SPTI used
    [23:23:51] NeroVision Nero API version: 7.2.0.3
    [23:23:51] NeroVision Using interface version: 7.0.5.6
    [23:23:51] NeroVision Installed in: C:\Program Files\Nero\Nero 7\Core\
    [23:23:51] NeroVision Application: ahead\NeroVision
    [23:23:51] NeroVision Internal Version: 7, 2, 0, 3
    [23:23:51] NeroVision === Scsi-Device-Map ===
    [23:23:51] NeroVision DiskPeripheral : SAMSUNG SP1213N nvatabus Port 0 ID 0 DMA: Off
    [23:23:51] NeroVision CdRomPeripheral : MATSHITA DVD-ROM SR-8585 nvatabus Port 0 ID 2 DMA: Off
    [23:23:51] NeroVision CdRomPeripheral : ASUS DRW-1608P nvatabus Port 0 ID 3 DMA: Off
    [23:23:51] NeroVision === CDRom-Device-Map ===
    [23:23:51] NeroVision MATSHITA DVD-ROM SR-8585 E: CDRom0
    [23:23:51] NeroVision ASUS DRW-1608P F: CDRom1
    [23:23:51] NeroVision =======================
    [23:23:51] NeroVision AutoRun : 1
    [23:23:51] NeroVision Excluded drive IDs:
    [23:23:51] NeroVision WriteBufferSize: 83886080 (0) Byte
    [23:23:51] NeroVision BUFE : 0
    [23:23:51] NeroVision Physical memory : 1023MB (1048048kB)
    [23:23:51] NeroVision Free physical memory: 611MB (626052kB)
    [23:23:51] NeroVision Memory in use : 40 %
    [23:23:51] NeroVision Uncached PFiles: 0x0
    [23:23:51] NeroVision Use Inquiry : 1
    [23:23:51] NeroVision Global Bus Type: default (0)
    [23:23:51] NeroVision Check supported media : Disabled (0)
    [23:23:51] NeroVision 2.6.2006
    [23:23:51] NeroVision NeroAPI
    [23:23:51] NeroVision 22:26:05 #1 SPTI -1066 File SCSIPassThrough.cpp, Line 290
    [23:23:51] NeroVision F: CdRom1: SCSIStatus(x02) WinError(0) NeroError(-1066)
    [23:23:51] NeroVision Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
    [23:23:51] NeroVision Sense Code: 0x24
    [23:23:51] NeroVision Sense Qual: 0x00
    [23:23:51] NeroVision CDB Data: 0xAC 00 00 00 00 00 00 00 01 00 00 00
    [23:23:51] NeroVision Sense Area: 0x70 00 05 00 00 00 00 0E 00 00 00 00 24
    [23:23:51] NeroVision Buffer x01036200: Len x1008
    [23:23:51] NeroVision 22:26:05 #2 SPTI -1066 File SCSIPassThrough.cpp, Line 290
    [23:23:51] NeroVision Existing drivers:
    [23:23:51] NeroVision File 'Drivers\PXHELP20.SYS': Ver=2.03.32a, size=20640 bytes, created 18/04/2006 23:34:55 (Prassi/Veritas driver for win 2K)
    [23:23:51] NeroVision Registry Keys:
    [23:23:51] NeroVision HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
    This isn't a burning problem. Stop using Nero to author.
    Feb 2004
    Australia
    First thing here ... read that output and notice one major problem ?
    1: Stop using the desktop as a storage area for input and output ...
    Good choice's :
    Input file's = c:\input
    Output file's = c:\output
    Try this ... desktop is a very specially controled and managed area by the os ... not by YOU ... leave it alone .
    Working with most file's on the desktop in a "temporary manner" can be done , but what you have planed is system intensive and might just be what's killing the process .
    2: Refrain from using non-alphabetical or non-numerical character's in file and folder name's ... you used "@" ... don't do this ... You can use "_" and "-" without issue's .
    3: Dvd-decrypter or imgtool's burn dvd's using nero's api to control burn setting's ... dvd decrypter can burn minidvd's to cd , where as nero will refuse .
    4: You may be experiencing a bad batch of media ... there are such thing's .
    5: Your dvd burner , even though it may have the latest bios update , it could be the cause ... double check hardware setup then trouble shoot all before suspecting dvd burner ... a few suffer from poor workmanship on electronic control circuit every now and then ... some have crap len's which either need a clean ... beyond that ... replace unit .
    Note : There have been unit's released that malfunction when pc system's use the extra 4 wire power connector ... if your pc dose use this , and burn's all , but will not burn dvd video ... this is the problem ... The unit should be returned under warrantee .
    6: Final software round up .
    Avi's = AVI2DVD , and vdub frameserving to bbmpeg for more control over mpeg2 output .
    Wmv , Asf = Window's movie maker (provided they are unprotected) , also super .
    Dvdauthorgui = authoring dvd from source file's and complete's project to specified output from user input
    Besweet = audio to ac3 , and multiple ac3 for dvd
    Vobedit = demux all supported dvd stream's from vob's
    CDBurnerXP Pro = why not , it work's fine for what it dose .
