Any one give me an ideal how good, trustable Nero CD/DVD test is.
I just install new DVD rom Lite on 16p9 as slave in my PC to replace 4 years old BTC DVD rom having skip and hang. I ran Nero CD/DVD test with new DVD rom drive and find out some of my back up DVD having so much erros on quality test, but good on scan test. What are the differences between the two?? All my DVD are all watchable on stand a lone and PC as well.
Thanks for advices,
//TOnny
Put it this way - Nero will never give the same results twice on the Disc Quality test, which should indicate how reliable it is. Changing the read speed will change the results too, so don't place any bets on it. ScanDisc test is probably a better indicator than Disc Quality test.
CD/Speed Disk Quality Test, is a good way to evaluate your burned dvd's, as long as you scan at the proper speed for your drive. Yes there will be some variance, but a disk that will pass a scan test today, may not play a week from now (RITEKG05's), and the quality test will give tell you whether your burn is of high quality, or if it's crap. I've run tests on multiple drives and received vary similar results from dvd's. There will always be some minor variations, but anything in the 90% and above quality test will be good, and anything 70% and lower will always be crap (as long as you are scanning at the proper speed).
Rob
Nero - Compliance test failed? whats up w/ this?
By BRYAN_B28 in forum Authoring (DVD)Replies: 11Last Post: 2nd May 2012, 02:13 -
Is there a small test video one can use to test Rec 601 / 709 conversion?
By Asterra in forum Video ConversionReplies: 5Last Post: 19th Jun 2011, 09:28 -
[b][url]TEST! TEST TEST! WHAT"S THE BEST?!!!!!!!111111
By lordsmurf in forum TestReplies: 0Last Post: 2nd Aug 2010, 03:30 -
Test,test amd propus 630
By budz in forum TestReplies: 20Last Post: 1st Jun 2010, 01:46 -
Nero "Disc Quality" test?
By tac7 in forum DVD RippingReplies: 2Last Post: 12th Jun 2007, 18:40
