I have an AVI file which is a movie recorded in Spanish and Englsih. When I watch it using Media Player Classic or VLC I have the option of listening to Track 1 or 2 for Spanish or English respectively.
When I convert it to a VOB video file using Cucusoft AVI to DVD 7.07 or Ulead DVD Movie Factory, the dual track feature disappears and I can only obtain the Spanish version whether I like it or not using PowerDVD.
How can I maintain the dual track feature on the DVD output?
Results 1 to 11 of 11
extract both audio tracks with virtualdubmod, streams->stream list.
convert with avi2dvd or convertxtodvd and add both audio tracks. -
When I tried to run VirtualDubMod 1_5_10_2_b2542, it hung with the message that it couldn't find corona.dll.
I downloaded corona.dll and inserted one copy in system32 and another one in the VirtualDubMod directory. When launched, VirtualDubMod now hangs without any error message displayed.
For Corona, I used WinZip instead of Express Zip to unzip. I don't think that could make a difference. -
Try downloading from here:
http://sourceforge.net/project/showfiles.php?group_id=65889&package_id=63653&release_id=352709If in doubt, Google it. -
I found a solution to the problem in the forum below but was unable to reach the site they suggested
http://forum.digital-digest.com/showthread.php?s=&threadid=21334 -
Using jimmalenko's suggested site, everything went fine.
In a preliminary phase, I created successfully a single audio track DVD using Virtualdubmod by selecting only stream 2 (English) versus stream 1 (Spanish).
Now, I'll try the dual stream solution as suggested by Baldrick. -
Things worked ok every time with AVI2DVD whenever I needed only one track . Now, if I want to use both audio tracks which I demuxed using VirtualDubMod, how to I define them in AVI2DVD? Apparently, this program picks up the two audio streams from the original AVI file and I don't find a way to point to the mp3 demuxed files.
change audio language
By natty in forum Newbie / General discussionsReplies: 14Last Post: 1st Sep 2011, 07:07 -
Convert DVD with choice of audio language and burned-in subtitle language
By theproof in forum DVD RippingReplies: 2Last Post: 24th Jun 2010, 17:34 -
Change audio language
By mew1033 in forum Authoring (DVD)Replies: 7Last Post: 24th Dec 2009, 05:31 -
Dual Language Films
By Witchypoo in forum Newbie / General discussionsReplies: 6Last Post: 29th Jun 2008, 05:42 -
Help extracting language track from dual audio video.
By ebisoba in forum Video ConversionReplies: 5Last Post: 9th Sep 2007, 13:53
