Results 1 to 13 of 13
  1. Member madman1987's Avatar
    Dec 2005
    Metal City
    Hello friends!!
    I want to create Video DVD of a TV series.It has 14 episodes each of 24 minutes.
    All these episodes are in AVI format with video byterate of 1000kbps and audio byterate of 128kbps.
    Is there any way to fit all these episodes on one DVD with no loss in quality.
    I want to create menus like in Nero Vision Express.
    I will play created DVD on Standalone DVD player not on DIVX player.
    Anxiously waiting for your reply!
  2. Member Moonstomp's Avatar
    Oct 2003
    Dublin, Ireland.
    The quick answer is NO.
    To fit 7 hours onto one single layer DVD will require a lot of loss of quality.
    Best to split this over 2 or more DVDs my friend.
    Moonstomp.
    Just because you're nobody, doesn't mean that you're no good. Just because there's a reason, doesn't mean it's understood. It doesn't make it all right ! (The Specials)
  3. Member oldandinthe way's Avatar
    Mar 2006
    With the other crabapples
    To fit the 7 hours on a dual-layer DVD you will get a lesser loss of quality.
  4. Member LSchafroth's Avatar
    Dec 2002
    What resolution are teh AVI files in now?
    LS
  5. You could use DL but only half of the players would play it.
  6. Member madman1987's Avatar
    Dec 2005
    Metal City
    LS
    Thank you very much for the quick reply!!
    And for your question. The resolution of all files are 640x480.
  7. Member madman1987's Avatar
    Dec 2005
    Metal City
    DL DVDs are not available in my country!
    Then what should I do!
    Apr 2003
    Maryland
    You have to author them to several DVD Rs. No way around that without masive loss of quality.
    No DVD can withstand the power of DVDShrink along with AnyDVD!
  9. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    A) 5 episodes/disc at close to the same q as your source files
    or
    B) Encode to VCD specs mpg and lose lots of quality, but may possibly cram it all on to one disc.
    /Mats
    Feb 2003
    using a bitrate calculator, I've detmined you'll need a bitrate of 1222 to fit 7 hours on a dvd (with 224 audio). The closest standard to this bitrate is VCD. VCD is 1150 kbit/sec MPEG-1 compression at 352x240, and 29.97fps. This, however, is a drastic decrease in quality. You can use TMPGEnc Plus (or another vcd encoder) to convert your files to VCD specs. Once they're VCD-complient, you can use TMPGEnc DVD Author to author the DVD. It will accept the VCD files as DVD-complient.
    I've also managed to tweak the VCD settings a bit in TMPGEnc,for better quality, and they're still accepted by TMPEnc DVD Author. I'll make the files VBR and crank up the Motion Search Precision to it's Highest level. With these settings you VCD's might not look too bad...
  11. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    The DVD specs for VCD frame size isn't limited to 1150 max as VCD - it's 1856 kbps. But nevertheless, it's low res, and low bit rate. And will be far from "no loss in quality".
    /Mats
  12. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Easy/Fast way:
    Use convertxtodvd, and do 7 eps each to a SL DVD or all 14 to a DL DVD.
    Longer/More control:
    Convert to Half D1 (352 x 480) using a dedicated encoder such as TMPGEnc and encode at 3000kbps CBR. Again, 7 eps should fit on a SL DVD or all 14 on a DL DVD.
    If in doubt, Google it.
  13. Member madman1987's Avatar
    Dec 2005
    Metal City
    Thanks mats.hogberg !
    Thanks akrako1 !
    Thanks jimmalenko !
