Ok first let me sya , this is the 1st time ive really tried to add subs, 2nd Ive looked at the posts above with directions an got the virtdub mod an the vobsub plugin,
But im still having probs , so i thought I may as well post my perdictiment an see if some kind soul would help,,,,thanks
the file got hjas the avi file we'll call it uhhhmmmm, homemovie1
then its got subs for
home movie 1 - idx
home movie 1 - sub
Now I went thru the motion w/ vdub , an its says something about error , do you want to rewrite audio headr?
I hit yes, it load ,
then when I get to the video /filter to add file an I click add TEXTSUB 2.23 , then it askes me to OPEN I click the file an nothing happens , like it wont take it?
So with all the probs listed above ,, is there a diff proceedure I can use to add these subs?
Results 1 to 9 of 9
Btw , now Ive done done somthing to my pc with adding the vidub mod, an the vobsub 2.23
cause now when i try to encode something w/ canopus Im getting a pop up that says th
the prodeure entry point ??? 4crendered Textsubtitle @@ QAEAAVO@ABVO@@Z could not be locted in the dinamic link library vobsub.dll''
Now what that all about>>>???
Cause now my encode is slow, it was zooming at like 33.fps now it starts at like 3 an eventually works up to about 17 fps.
Now Im Pissed()*^)&^ AHHHHHHH!!!!!!!!
geez now what do I need to to to fix this,, cause I went to uninstall the stuff but its not in the add/remove programs? -
thanks alot for the reply an help dude , but when i installed this thing i did it from the link on the site, an it said install it to the folder where virtdub is located, so thats what i did. Now Ive went an delted all the folders ,, everything except for the lil installer that I got from here , incase I needed to re-install it. same for vdub , I went thru my registry an deleted all the freeware folder which vdub is vdub , an the gabset folder which was for vobsub 2.23
now as pere your instuctions - I went to my program files folder in the pc hd section an deleted the gabset folder with the vobsub stuff there too , but I didnt see no folders that pertainedd to virtdub ,,
anyhow I cant seem to find the folder with an with an excute exe uninstall .
but anhow my cnoapus is still doing this, an I even un-installed it, [tryed to repair it 1st]
deleted any folder ness to it, an re-boot then re-install it all over then , then reboot - again - then tryed - -
and still getting the aggrivat'n pop up , an its still slowin it down at first..
and this is damn brand new PC , I aint had it a week , an im afraid if I keep looking for stuff to delete an messin with the registry Im gonna end up f'n something else up , that hasn nothing to do with this.
But , now that i think of it is there a way I can add the subs thru canopus - while I encode an avi file to an mpeg1 file??
DESPERATLY CONFUZED???!?!?!?!?!?!?!?
thanks -
ok , let me ask this again , so lets start fresh,,
whats the best way for me to get these subs onto the movie?
some directions if ya dont mind, I tryed the directionsnfor the other way an didnt have any luck, an mess my system a lil bit in the process,,
so lets start from scratch,,
file - homemovie.avi
subs - homemovie.idx
homemovie.sub
now do do I make it just plain
homemovie.avi [with the subs showing up in the final product]?
BTW, I know this may sound like a newbie dumbass questions?
cause when it come to this i guess you can call me a newb, although ive been at this junk for years Ive never evn not 1 time tryed toadd subs,
thanks alot everyone for your help an patience! -
homemovie.sub
or
Sub2DivX
They both work for me with idx/sub in the same directory. Sub2divx needs bmptoxsub.exe and DivXMux.exe which were not in the install I selected but had links on the same download site.
btw) The output file will have a .divx extension which you can rename to avi if you want.
I've also been at this a long time but just started playing with subs. -
Whooaaa Haaa,,
Ok I used the Avisub an finally got it going,, an it came out like
avisub,divx etc or whatever - now I can play the file on the divx player an nothing else,
Now How can I enocde this thing to a mpeg file? to put onto a dvd?
when i try to open it with canopus its not showing up in the menu,
even if i click show all files - its still not there
any Suggestions? thanks
How do I add .srt subs to avi?
By 12 gage in forum SubtitleReplies: 16Last Post: 1st Jun 2014, 16:58 -
add subs failed.
By izzykatz in forum SubtitleReplies: 2Last Post: 2nd Jan 2011, 16:52 -
Add Subs
By AntiBaltak in forum SubtitleReplies: 11Last Post: 9th Nov 2009, 18:00 -
How do i add subs to my videos?
By mrjust in forum Newbie / General discussionsReplies: 1Last Post: 14th Jul 2009, 18:29 -
DVDSTYLER - how to add subs
By ricardouk in forum Authoring (DVD)Replies: 4Last Post: 25th Jun 2007, 13:43
