HI ,
first of all please forgive me if my language is not very technical.In summary when I had a file video in my pc and I wanted to create a DVD, following your instructions, I used first MPEG encoder and then TMPGencoder.
last week I had a problem in my pc and I boght a new pc. Now I tried to use MPEG encoder but when I download the program ( open) a message appears "no video data found" (??!!??) strange because the video does exist. Now my question: do you understand the problem behind? is ther another program that I can use in place of MPEG encoder?
Thanks a lot/Fabio
If you not very technical, easy to use program better for you. Encoder then burner too complicated for you. Use simple program like Baldrick suggests better for you.
Pero si quedes escribir en Espanol, es posible que hay alquien aqui que podemos responderlo.
which is better Mainconcept MPEG Encoder or H.254 Encoder
By d_unbeliever in forum Newbie / General discussionsReplies: 7Last Post: 4th Aug 2012, 18:14 -
Some Mainconcept MPEG Encoder questions.
By scott274 in forum Video ConversionReplies: 9Last Post: 15th Jul 2008, 03:08 -
MainConcept MPEG Encoder 1.5 question
By hanugro in forum Video ConversionReplies: 6Last Post: 21st Feb 2008, 20:27 -
Avi to DVD (mpeg2) in Mainconcept Mpeg Encoder, basic how to
By reboot in forum User guidesReplies: 31Last Post: 6th Aug 2007, 15:56 -
MainConcept H.264 Encoder Error
By cowboysroy31 in forum Newbie / General discussionsReplies: 0Last Post: 22nd Jun 2007, 19:06
