Hello. I have a a few .ts files which my IO Data Avel Link AVLP2/DVDG network media player cannot play. I have thought about a firmware update but it seems quite a minefield with this company. So, I have been re-encoding them to MPEG2 with HDTVtoMPEG2 trying to keep the file size as big as possible. My question is: does this affect the quality/resolution of the files. Is it lossless? I don't want to burn to DVD but keep maxiumum quality for viewing in hi def. Thanks...
dastott,
If you change the file extention from .ts to .mpg the LinkPlayer2 will play them without problem.
Using HTDVtoMpeg2 creates another file with no loss of resolution and is about the same size as the original .ts file.
Chas -
Guest34343GuestOriginally Posted by Megahurts
If the whole transport stream is captured, the LinkPlayer2 will default to the first sub-channel.
I capture using 'sub-channel only' which also makes for smaller file sizes.
HDTVtoMPEG2 Question
By beanosirra in forum Capturing and VCRReplies: 2Last Post: 25th May 2010, 03:38 -
Are all decrypters lossless?
By sldvd in forum Newbie / General discussionsReplies: 2Last Post: 28th Mar 2010, 23:43 -
opinions on method to convert DVD to MPEG2 lossless
By fotty in forum DVD RippingReplies: 14Last Post: 21st Feb 2009, 06:48 -
How to Capture DV on Lossless?
By Undead Sega in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 43Last Post: 27th Aug 2008, 20:10 -
VOB to MPEG2(lossless)
By santosh86 in forum DVD RippingReplies: 1Last Post: 6th May 2007, 14:29
