  1. I'm fairly new at all this, as I've only converted a couple dozen so far. My question is I'm wondering how to increase video quality. I know this might sound lame, but as I said, I'm fairly new, so please take it easy. My idea was, since I'm using 2 cd's anyway, why not try to fill them both up, and get better vid quality? I've been seeing the "let's make the whole thing fit on one cdr at a little bit of a loss", or the "New Format" threads, but it's all greek to me at this point. I'm thinking increase the bitrate? And will that affect playability in my DVD (Panasonic DVD-RV31) player? I can play non-standard VCDs, in case that's a question that will arise.
    Any help is appreciated!
    ScrapHeap
  2. What encoder are you using? My favorite is TMPGEnc. If you are using TMPG simply follow these instructions step by step ->
    http://www.vcdhelp.com/tmpgencxvcd.htm
    When entering the bitrate (yes, for better quality, a higher bitrate definately helps ) use VCDHelp's bitarte calc found here ->
    http://www.vcdhelp.com/calc.htm
    Good luck and let us know if you don't undersatnd anything in the "how to" page
