Closed Thread
    Jul 2003
    Hi,
    I would like to record what's on my desktop screen to VHS.
    I have a Nvidia GeForce FX 5200 TV Out card with a S-Video port on the back.
    If I connect a VCR to the Graphics card using The S-Video will this be enough?
    Will this only give me picture and not sound.
    How and what do I need to use?
    Many thanks in advance
  2. Member Abbadon's Avatar
    Dec 2003
    Caribbean Sea
    Yes,
    You can record what you see on your computer's screen to VHS, but the quality will be ugly. Trust me, I have been down this road before recording myself playing Unreal Tournament 2004.
    You only need to enable TV Out, connect your S-Video cable to the Video In of your VCR and then using an adaptor for the Sound out connect a sound cable to your VHS Audio In.
    The best quality would be recording to a second computer with Video In or using a TV card with S-Video in to the second machine.
    No tengo miedo a la muerte. Solo significa soņar en silencio. Un sueņo que perdura por siempre. ..
    USA
    One post per topic is enough. Don't double post. Moderatior redwudz
