I have implemented a modified HRTF (head related transfer functions) based surround panorama simulation with the use of stereo headphones.
Our decoder can be downloaded from:
http://www.aud-x.com/content/view/12/26/
Some basic facts: What is HRTF filtering?
The basic question is why do we perceive sound direction, while having only
pair of ears (i.e. this seems to be sufficient for stereo, but why does it work for surround sound perception?).
The answer is that we in fact our ears receive only a stereo signal and than the surround perception is generated by our brain. Since our head, shoulders and ears cause some acoustic wave reflections, based on this our brain is able to ‘guess’ what is the source direction.
The idea is to emulate such reflections in digital domain (with some DSP operations), before playing with stereo headphones, so listeners brain should be able to ‘decode’ such stereo source to surround.
And indeed it works great, however only in case of very precise simulation of individual’s
shoulders, head and ears shape. So the generalized solutions tuned for an average listener usually
are pretty disappointing, and the sound is usually perceived as a linearly distorted stereo signal,
rather than surround (we differ much from each other, in terms of body shape)
The algorithm that I’ve implemented affects only phase of the signal, without the linear distortions. This however significantly limits vertical direction perception, and also limits surround speakers direction perception. In order to overcome this limitation, I have added a reverb algorithm, which emulates sound propagation in a 20 square meters room (4m x 5m). This is not a normal reverb effect, because for the left surround channel, the impulse response has been emitted from the surround left speaker position, and recorded in the sweet spot with a microphone directed towards the surround left speaker. Similar procedure has been applied for the surround right (impulse generated in the right speaker position, and room response has been captured with a microphone directed towards the right surround speaker).
Based on the gathered impulse responses, a simplified IIR filter coefficients have been calculated (in order to decrease computational complexity of long FIR convolutive filtering with the use of the room impulse responses).
Front channels (FL, C and FR) have been simulated only with the use of phase adjustments, coming from the HRTF concept.
There is still a lot of room for improvements, but I think the result is very promising.
Please test it and provide some critical comments!
If you have any questions, I’d be happy to answer them.
The algorithm (embedded in our DSfilter) can be applied for any 5.1 source,
So it can be used for AC3 stream for example.
Hare is some test clip (in Aud-X MP3 5.1 format).
:thanks: , 3d
test%20-%20audx_mp3_5.1_128kbps.mp3
Please note, in order to test it,
you need to install our decoder.
It should indicate that the Aud-X stream is reproduced. -
Here is some additional AC3 clip,
Please test it with
* Aud-X virtual surrond (VS) algorithm
* FFDshow HRTF algorithm (to see what I mean by linear distortions)
* AC3filter (to see the difference between the VS algorithm and a regular stereo downmix)
zzz_fifthelem_orig48.ac3
stereo downmix: surround vs surround 2
By codemaster in forum AudioReplies: 7Last Post: 29th Aug 2012, 12:06 -
Are surround sound headphones worth the money?
By yoda313 in forum Off topicReplies: 0Last Post: 31st Jul 2011, 00:17 -
I keep losing stereo audio on my stereo bluetooth headphones (vista)
By yoda313 in forum ComputerReplies: 0Last Post: 30th Jan 2010, 10:19 -
"stereo" file (two channel signal) - Surround or Stereo?
By zee944 in forum AudioReplies: 0Last Post: 4th Sep 2009, 06:53 -
RCA stereo audio to Headphones
By MokaChick in forum AudioReplies: 5Last Post: 4th Jul 2007, 17:54
