I wouldn't. I would just feed the avs file into CCE, configure CCE for the encode, and let it go. That's how I do mine. FitCD will give you and avisynth script that outputs a correctly sized video at full d1 resolution, ready for encoding. If AVI2DVD didn't get it right the first time, why put it in the middle again ?
Read my blog here.
Ahhhh yes, but your DVD player will want you to conform to DVD-Video specifications and the original's video image size is not DVD-compliant. Used properly, FitCD will give you a script which resizes to a DVD-compliant frame size whilst retaining the correct aspect ratio.Originally Posted by keregiozIf in doubt, Google it.
virtualdub: input video distorted on 32 bit but not 64 bit
By iggogg in forum EditingReplies: 18Last Post: 5th Oct 2011, 02:34 -
64-Bit Vegas Pro 9 fails to open 64-bit UT Video Codec Pack
By Smells_Like_Feet in forum EditingReplies: 1Last Post: 2nd Oct 2011, 16:14 -
64-bit Video Convertion Program
By Trickynick in forum Video ConversionReplies: 15Last Post: 25th Feb 2010, 18:57 -
Video convertion
By kireetkvn in forum Newbie / General discussionsReplies: 3Last Post: 10th Sep 2007, 01:50 -
Vegas - add image to video (DVD(mpg)) and moving image around
By psxiso in forum EditingReplies: 4Last Post: 11th Jul 2007, 05:29
