Can anyone give me the dirty on backing up DVD using ISO files vs. using TS folders.
Is one method better than the other or is it a matter of preference. Also, is there freeware available with the option of performing both burns?
Mostly preference, but the ISO backup allows you to burn back to DVD with a larger number of programs, while the Video_TS method requires you use burning software that has video DVD creation/support capabilities.
Free versions of burning software for both. -
Does one the these methods handle the "layer break" better than the other with DL media?
I also would encourage the usage of Dvd Decrypter in Iso mode (Read) and then ImgBurn for Iso write. I find that Decrypter does a great job with the layer break.
MovieDud -
i output to ISO, simply because i prefer to burn with Imgburn. i find it gives marginally better burn quality than any other burning program ive used and it supports advanced settings for BenQ and/or Plextor drives, such as Solidburn, WOPC etc.
for DVD9 copies, i agree, DVD Decrypter ISO read, then ImgBurn ISO write is the best method. however, since DVD Decrypter isnt updated anymore, you may have troubles with newer movies. this is why i use AnyDVD with DVD Decrypter. a free alternative to AnyDVD, is DVD43. -
I always use AnyDVD and DVDDecrypter.
There is one thing I always do though incase of conflicts between the 2 tools.I let AnyDVD do all the protection removal and change settings in DVDDecrypter.I set the I/O to ElbyCDIO or SPTI,disable checking for structure protection,disable macrovision,disable region code,CSS ect....
Just to be on the safe side.~Luke~
Folders changed into 32 kb files, help!!
By caesarhawy in forum ComputerReplies: 1Last Post: 27th Apr 2011, 13:57 -
No BDMV Or Certificate Files/Folders
By PM5K in forum Authoring (Blu-ray)Replies: 1Last Post: 27th Jun 2010, 03:14 -
Adding extra folders or files to BD Disc
By jntaylor63 in forum Authoring (Blu-ray)Replies: 2Last Post: 2nd Feb 2010, 13:48 -
Blu-ray ripped files to hard drive in Folders not un ISO Image
By judgmentday in forum Blu-ray RippingReplies: 2Last Post: 21st Sep 2008, 14:26 -
Advantages - disadvantages to burning video folders or burning an ISO img
By theewizard in forum Authoring (DVD)Replies: 14Last Post: 26th Jun 2007, 15:19
