Is it possible to Copy a Disc Menu from 1 disc to another?
I had a set of avi's that i converted to dvd, then created menus for and then burned to 4 discs.
I have since lost my disc #2.
I do still have the avi's on my computer, but have none of the menu jpgs or sound, and can not find them anywhere.
So my question is, is it possible to copy the menu from one of the other discs in the set to a new disc #2?? and if so, what tools do I need to get to accomplish this??
I hope I elaborated enough, Any help is GREATLY appreciated.
Check out this post.
https://forum.videohelp.com/viewtopic.php?t=301393&start=0&postdays=0&postorder=asc&hig...%20menu%20copy
or do a serch on all forums at the top of the page.I want to believe.... -
Here's a page that may be of some help:
http://jsoto.posunplugged.com/guides/VobBlanker/adding_menus/index.htm
The parts relevant to you would be replacing the main movie using VobBlanker, starting about step 6. So rip the one with the menu and replace main movie. Good luck.
Pull! Bang! Darn! -
Thank you both VERY much!!!
I did try searching first, but must have been putting in the wrong criteria, cause I wasn't finding anything near what I was looking for.
Thanks again
How to copy DVD 9 to 5 with menu & extras using DVD2ONE.
By BarryHL in forum User guidesReplies: 145Last Post: 24th Mar 2011, 09:36 -
Perfect DVD copy with all the menu's but half the file size
By Kozanator in forum Newbie / General discussionsReplies: 12Last Post: 5th Mar 2009, 10:44 -
How do i copy dvds onto hard drive and what is best software to copy sav
By bfishwick in forum Newbie / General discussionsReplies: 1Last Post: 13th Feb 2009, 18:29 -
Trying to copy a dvd made using convertxdvd no menu shows up
By brdhsby5 in forum DVD RippingReplies: 18Last Post: 17th Apr 2008, 10:33 -
DVD Lab "the subpicture of menu 1 is created from copy of external fil
By BeachNut in forum Authoring (DVD)Replies: 4Last Post: 26th Jan 2008, 09:05
