First of all - thanks to everyone for all of your expertise. I have been fitting the DVD converting/burning puzzle together slowly over the last couple of weeks and wouldn't have been able get this far without your collective help.
__________________________________________________ ______________________
I have hit a snag and, although I have looked, I don't see/kind find any posts that address this specific problem.
I'm using a P4 2.8 g, 1 gig ram, plenty of HD space (20 gigs allocated for converting files) - XP pro sp2.
I have various AVI files and use AVItoDVD to convert to burnable DVD files. I don't tweak anything in AVIto DVD (I leave the same screen ratio/audio settings). It converts and I am then able to burn the file. I have used various converting options all with the same effect)
I burn the DVD using NERO burning ROM (I got with the DVD burner - Nero 6). I have a relatively new ASUS DVD burner - and I have cut the burn rate from 8x to 4x (although I have tried both).
The DVD burns fine - and they work on my Toshiba DVD player (I think it's Toshiba - I'm at work now and it's at home - probably playing Little Mermaid for my girls).
However, at various points, the burned DVD movies pause during playback. It doesn't seem to have any reason to pause - it's not at a chapter - and it pauses in different places with different movies (for example, Movie 1 will pause in the same place each time it is played - like at 10:25, for example - while Movie 2 will also pause in the same place each time it is played - like at 25:25 and 26:30 (those times are just for explanatory purposes, not the actual time it pauses)).
I don't do anything, or have any programs running while converting OR burnng - and the processor doesn't seem to be overheating or overworked.
I have checked and installed all of the newest drivers, windows updates, Nero updates and patches.
Finally - on just one movie (and I guess this is a separate problem - but maybe not) I follow the above described converting/burning procedures - and yet playback has a horizontal roll - just like you used to get on your old TV set.
The only other thing I can think of is that the DVD player is connected to the TV (just a regular TV) via component cable - the one with the red, blue and green - not the RCA composite connection or S-Video.
Commercial DVDs play fine - it's only the DVDs that I burn that has problems. (Imation DVDs RW +/- 4.7 gigs).
Let me know if you need additional information from me to help figure this out.
Thanks in advance.
Have you tried other dvdmedia than imation?
And try another converter like convertxtodvd too see if it helps.
Horizontall roll is probably because of PAL, be sure to set output NTSC in your converter. -
Thanks Baldrick -
No, I haven't tried any other media.
I am trying Convertxtodvd right now and will try the PAL to NTSC on that one movie soon.
Two other things -
1) The DVD player is a Pioneer
2) The media is imation + R x16
Don't know if this makes much of a difference.
Scrolling horizontal lines during VHS playback HELP
By daysaf00 in forum Capturing and VCRReplies: 5Last Post: 29th May 2011, 04:01 -
.MTS file sequential playback pauses between files
By Davecom4.6 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 10th Jun 2009, 23:53 -
Pauses between the chapters during playback
By roblobster in forum Authoring (DVD)Replies: 8Last Post: 8th Feb 2008, 23:54 -
divx pauses during playback
By poppinjay in forum Newbie / General discussionsReplies: 6Last Post: 8th Oct 2007, 20:41 -
Horizontal lines on video playback with vista
By richard.fisher in forum Software PlayingReplies: 7Last Post: 4th Jun 2007, 09:48
