What settings do I need to turn on/off in order to rip a DVD and leave the region codes intact? I do not want the ripped DVD to be region free.
Go to Tools --> Settings --> and whichever mode you're ripping in, whether its File mode or ISO Mode, uncheck the "Remove IFO RC protection" box.
You can always use DVD Shrink to set a Region Code. -
Thanks Waheed. I can't use DVDShrink as it looks like one of my DVD players will not play a DVD is it's been shrunk.
DVDShrink also removes region codes by default.Originally Posted by sawbo1
If you need to further compress a DVD with DVDShrink...just assign
it a region code and it will be the same as assigning/not removing
the region code in DVDDecrypter.
A region coded DVDR is the same...no matter what program it
comes from...it is still a DVDR.
Editing Video And Keeping Same Encoding Settings
By codeseven in forum Newbie / General discussionsReplies: 1Last Post: 16th Apr 2011, 01:44 -
DVDDecrypter wants to set Region Code
By src2206 in forum DVD RippingReplies: 6Last Post: 15th Feb 2009, 12:38 -
DVDdecrypter region code not set. Help
By X_Splinter in forum Software PlayingReplies: 2Last Post: 9th Sep 2008, 18:08 -
Problem with Region settings
By paulgold in forum DVD RippingReplies: 11Last Post: 18th Apr 2008, 22:47 -
Region settings help
By ian curtis in forum Software PlayingReplies: 6Last Post: 7th Dec 2007, 08:19
