  1. Does anyone know of software I could use to convert mpegs and Quicktime movies to AVI? I would like to hotsync them to my PDA but it will only play AVI's. Thanks.
  2. The QuickTime Player Pro (registered) version can convert MOV and MPEG-1 files to AVI. I'm not sure what AVI codecs it supports however, and you would also need to know what AVI codecs your PDA can play.
    Apr 2001
    On 2002-01-05 23:03:37, JHebert wrote:
    The QuickTime Player Pro (registered) version can convert MOV and MPEG-1 files to AVI-
    </BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
    - not very well. Good luck to you.
    It's a slow process, and I've had very bad luck with it personally. The only way I ever got it to work on some clips was to open it in a Quicktime-aware editing program (like Premiere), and totally re-encode it to the format you can use (AVI). Even the "Uncompressed AVI" format is buggy and erratic with Quicktime Pro, so good luck once again.
