I use "Scenarist"
How to make a dvd with the size of 352*240
Thanks in advance !
You spent $000's on a piece of software you don't know how to use ? I wish I had that kind of money.
You have to upsample the audio to 48khz, after which you should be able to add it as any other asset. Assuming this was originally VCD, the audio will still be 44.1khz, and should be the only thing hold you back from using it.Read my blog here.
He didn't buy it!
No DVD can withstand the power of DVDShrink along with AnyDVD! -
For all we know he has gov't sponsorship that funds 352x240 movie production and issues legit $5000-35000 software with hardware to deserving candidates.Originally Posted by jtoolman2000
I hope showmystage will let us know if we are able to apply for consideration. He must be very smart or very rich or something else. -
One can only hope
showmystage, if you look to the upper left under 'What is' DVD, you will see that 352 X 240 is a valid size for NTSC DVD video. As mentioned, all you need to do is convert the audio to a 48Khz rate. You can do this automatically with a program like TMPGEnc DVD Author, or with most audio editors. If the video is from a VCD, the audio is probably MPEG-1 Layer2. You can use Gspot 2.52 to see what the audio and video format of your file is.
If you need specific information on Scenarist, you can go to their webpage:
http://www.sonic.com/products/Professional/Scenarist/quicklook.aspx
How do i make a video the same size/specs as another one I have.
By PhenotypeX in forum Video ConversionReplies: 7Last Post: 11th Mar 2010, 13:52 -
How Do I Make a P-Size Switch on Samsung LN46A650A1FXZA
By hammec in forum Newbie / General discussionsReplies: 4Last Post: 5th Jan 2009, 18:57 -
How do you make screen size bigger on Philips dvd model DVP642?
By jkristoff in forum DVD RippingReplies: 9Last Post: 23rd Jul 2008, 05:33 -
Any way to make video size in virtualdubmod smaller?
By weirdduck88 in forum Newbie / General discussionsReplies: 2Last Post: 13th Jul 2008, 16:40 -
Isn't 360 x 240 a viable size?
By bneubert in forum ffmpegX general discussionReplies: 2Last Post: 19th Jul 2007, 19:03
