    Feb 2006
    is there anyway to re do dvd menu's once the dvd has been created, have made a few mistakes on some dvd's i've made and would like to correct them
    kind regards
    johnny
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Well there are a few tools around which allow you to manipulate menus but the easiest way would be to redo the DVD using the *_S2D.mpg files. This way those file will not be reprocessed and you can recreate your menu.
