I have 2 x avi files 1x716,074 KB & 1x719,866 KB in size.
What i would like to do is to put both files through S2D so that the finished output file can be burnt to 1 dvd disc.
I have converted a few avi files in the past but only 1 avi file per disc and as it takes a long time to do i thought it would be better to ask first.
Also will i encounter any problems like quality etc,any guidance before i start would be nice.
Cheers
The size of the aource avi files is not important - the duration is. Any duration upto 3 hours will give good results (in most cases). So just add them as assets and put them in the same VTS (if they are two parts of the same movie), and off you go as normal.
Another H264 to AVI Question
By kenzier in forum Video ConversionReplies: 4Last Post: 20th Feb 2011, 01:59 -
question about avi files
By tlrbjc in forum Newbie / General discussionsReplies: 5Last Post: 17th Jul 2009, 14:54 -
VOB to avi question
By nalooti in forum Video ConversionReplies: 2Last Post: 3rd Jul 2009, 18:16 -
For VOB files to AVI, I use avi.net . . Question
By nhbfan12345 in forum DVD RippingReplies: 4Last Post: 11th Sep 2008, 00:02 -
AVI to DVD question
By cajmere in forum Video ConversionReplies: 3Last Post: 6th Dec 2007, 15:29
