I have some concert footage I am remastering. I am adding a better audio source and using noise reduction filters to clean up the VHS source. I am recording to a stand alone DVD recorder and then transfering them to PC using DVD Dycrypter. I frameserve the file into Sony Vegas using DGIndex and VFAPI codec to sync the audio and video and do some basic editing. I want to use TMPGenc for the noise reduction filter and cropping. Can I frameserve out of Vegas into TMPGEnc or can you not frameserve through multiple programs. I have limited hard drive space and cannot save a large avi file. Thanks!
Ah! I knew there had to be a program that would support frameserving out of vegas. I tried frameserving from TMPGenc into Vegas but it caused a loss of sync between the audio and video. I was just basicly trying to figure out if you could frameserve through multiple programs or if that could cause sync problems. Thanks for the link. I will give it another go.
How to frameserve DVD/MPEG2/HDTV to an advanced video editor
By Baldrick in forum User guidesReplies: 55Last Post: 14th Feb 2010, 11:22 -
What is the best advanced multitrack audio editing software ?
By 3thman in forum AudioReplies: 8Last Post: 11th Dec 2009, 09:45 -
Invalid DVD / Multiple errors with multiple programs...
By multiplex in forum Newbie / General discussionsReplies: 10Last Post: 6th Oct 2009, 16:50 -
Cuttermaran & Advanced Editing.
By bijoythulas in forum EditingReplies: 0Last Post: 1st Oct 2008, 21:47 -
Need software for advanced editing (moving objects)
By eric0524 in forum EditingReplies: 13Last Post: 7th Jul 2007, 21:05
