Hi all,
Before I go on, can someone explain why it's so common to add an echo to the surround channels when dealing with a song, but not when dealing with movies?
That said, again, I'd like someone to check out some short clips I mixed. 3 of them are from different songs (ac3), one of them is my sad attempt to create a 5.1 mix from a film's mono soundtrack (ac3) and the other is simply a clip from The Terminator 1 (mp3), demonstrating what I was curious about before, regarding how when a 5.1 mix is created, certain channels contain mostly vocals and nothing else.
Please give them a listen. Here are the links:
Candlebox - Cover Me (ac3 clip)
http://www.filegone.com/iz8v
Rush - The Spirit Of Radio (ac3 clip)
http://www.filegone.com/sxq9
Rush - Yyz (ac3 clip)
http://www.filegone.com/lapx
The Terminator 1 (mp3 clip)
http://www.filegone.com/bxcu
When A Stranger Calls (ac3 clip)
http://www.filegone.com/d6ws
Thanks in advance for any comments, suggestions, etc.
- Justin
with a song the instruments/vocals are expected to be processed and processed again with fancy fx.
with a movie the aim is realism and recreating the environment of the film..so unless they are walking through a metal pipe or in a tiles room reverb would be out of place.
Capture Short Video Clips From 1.5 Hour DVD
By Grassman in forum Newbie / General discussionsReplies: 2Last Post: 27th Mar 2012, 00:52 -
Need to record short vid clips from DVD's...Best method?
By BlueProteus in forum Capturing and VCRReplies: 15Last Post: 11th Dec 2011, 10:47 -
Can I do a simple fade in/out on clips pulled from BD without re-encoding?
By Dan Miller in forum EditingReplies: 4Last Post: 7th Jun 2010, 00:31 -
A short, simple, answer about core 2 CPU and DDR2 memory
By DB83 in forum ComputerReplies: 5Last Post: 9th May 2008, 19:59 -
Simple tool to make video from photos and short clips?
By largactyl in forum Newbie / General discussionsReplies: 4Last Post: 23rd Jan 2008, 11:45
