This is probably a stupid question but i need to ask it anyway...
How come when converting a DivX video to DVD there's quality loss?
I mean the divx movie files are about 700MB and the resulting DVD is 2 to 4 GB average... There's no compression going on... right?
I use Avi2DVD for these convertions, is there something better you can suggest?
You are reencoding to another video format and dvd mpeg2 is not as good as DivX at lower video bitrates(low bitrate = smaller file size)...so to keep similiar quality it will be bigger.
and divx to dvd is not dvd to. moving you. -
..and every conversion to a not lossless format (like mpg) will make the quality lower no matter what you do.
Yes, there is compression going on. During reencoding, every frame in the source DivX is decompressed, and that frame is then compressed using another algorithm.
Multipass VBR encoding using a dedicated mpeg encoder like CCE is the way to go for best results.
/Mats -
Ifoedit support's these dvd specific resolution's :
Pal
720x576
704x576
352x576
352x288
Ntsc
720x480
704x480
352x480
352x240
Choose one that is close .
Then there is video bitrate ... you need to figure this out , best do a couple of test sample's ... to see which would give best result .
Resize clip to choosen ifoedit supported format ... in vdub , video resize filter , stretch both till width is chosen width , and box height ... this keep's the aspect from being messed about .
All encoding is to mpeg2 format ... bbmpeg support's all output's (frameserving from vdub to bbmpeg) .
Newbie Divx question
By Contact in forum Newbie / General discussionsReplies: 13Last Post: 13th Apr 2009, 10:57 -
4:3 LBX DVD to Divx cropping question
By ecc in forum Video ConversionReplies: 3Last Post: 1st Oct 2008, 12:11 -
Philips DCP850 DivX overall quality (and DivX subtitle handling) question!
By mabhz in forum DVD & Blu-ray PlayersReplies: 0Last Post: 3rd Jul 2008, 18:59 -
DivX question
By didikai in forum Newbie / General discussionsReplies: 11Last Post: 18th Jun 2008, 20:22 -
Divx converting question
By KilinKind in forum Video ConversionReplies: 2Last Post: 15th Jan 2008, 18:25
