Hi once again,
OK - From looking at reviews of your Capture Card on this site : https://www.videohelp.com/capturecards.php?CaptureCardRead=9
it seems that the software supplied with the card will NOT allow you to capture directly to MPEG2. In fact most users described the supplied spftware as next to useless !
If you want to get to MPEG2/DVD, here are your choices:
1. Capture to AVI, as previously described, using Virtualdub / VirtualVCR. Then encode to MPEG2 using Tmpgenc. (It won't take any longer than MPEG1 to MPEG2)
2. Try out some decent capture software (download a trial version) & capture direct to MPEG2. If it works well for you then consider buying it.
There is a listing of Capture software here:
https://www.videohelp.com/tools?s=5#5
Good luck !!
Moonstomp.
Results 31 to 36 of 36
Just because you're nobody, doesn't mean that you're no good. Just because there's a reason, doesn't mean it's understood. It doesn't make it all right ! (The Specials)
No. HuffYUV will take less CPU power than MPEG while capturing. Then it will take up less encoding time (but not much less) when converting to MPEG later. Capturing with HuffYUV and converting to MPEG later will give the best picture quality because you will only have one round of MPEG compression artifacts and you'll be able to use an encoder that can take its time doing the best job (as opposed to a real-time encoder which has to take shortcuts to make sure it doesn't fall behind during capture). The problem is the large file size created by HuffYUV (about 30 GB/hr at full D1, 1/4 that at the quarter D1 you're capturing at now) because it uses a lossless compression scheme.Originally Posted by soneman
Capturing in MPEG1 and converting to MPEG2 will give you two rounds of compression artifacts, the quality can only get worse. Capturing in MPEG1 and burning that directly to DVD will give better quality. Capturing with a lossless codec like HuffYUV and converting to MPEG once will give the best picture quality.Originally Posted by soneman -
The problem with Mainconcept PVR and PicVideo mjpeg is that both are trial versions. It effectively means that I can try capturing with these two programs once or twice and then I'm unable to use it again until I actually purchase the software.Originally Posted by ronnylov
Thanks, but no thanks. I think I'll stick with what I've got. -
If you want to go the FREE way - you're best to go the avi route with Virtualdub / VirtualVCR.Originally Posted by soneman
Don't expect to get MPEG2 capture software for free.
Moonstomp.Just because you're nobody, doesn't mean that you're no good. Just because there's a reason, doesn't mean it's understood. It doesn't make it all right ! (The Specials) -
At last, common sense starts to return to the thread. Your hardware is easily up to the job, it is no different to what everyone was using 3 or 4 years ago and it was considered the ultimate then! I agree that the PicVideo MJPEG codec could be a good way forward for you. I used to capture with Virtualdub and PicVideo in full resolution (720 x 576) PAL on a 600 MHz Athlon based machine. Admittedly, you will be capturing to AVI and will then have to encode to MPEG2 so it will add some time but the quality will be fine.
I suspect the bit in the setup for your card mentioned only applies if you have paid for an optional MPEG2 encoder. A lot of the cheaper cards do that, the card is capable but only if you have the plugin for the software. -
I've tried Mainconcept PVR. It's got some decent features. But when I tried capturing in MPEG2 with maximum quality, the video started skipping and jumping towards the end of the video. It was playing fine with a lower quality setting.
But I don't think it's the solution I've been looking for. I don't know what it is but the picture looked better with a MPEG1 capture through SoftPVR than with a MPEG2 capture through Mainconcept PVR. For a start, I can adjust the brightness, contrast, sharpness and colour settings (hue, saturation) in SoftPVR (which makes a huge difference to the picture quality by the way). But I can't in Mainconcept PVR.
This is where the quality gets lost.
I've tried capturing in AVI aswell. There's no improvement in quality - with or without the use of codecs.
Thanks for the suggestions everyone but I think I'll stick with capturing in MPEG1 and then go from there.
What is the best format to convert VHS-C tapes to?
By Theresa in forum Newbie / General discussionsReplies: 16Last Post: 15th Jun 2014, 10:26 -
Convert VHS or U-matic tapes to any digital format
By predatorz6 in forum Newbie / General discussionsReplies: 4Last Post: 16th Feb 2012, 07:36 -
Convert old VHS-tapes to mpeg2?
By Mållgan in forum Capturing and VCRReplies: 10Last Post: 19th Nov 2010, 07:30 -
Capturing VHS tapes on pc
By BeachNut in forum Video ConversionReplies: 3Last Post: 12th Jul 2008, 22:08 -
Capturing VHS Tapes...
By soneman in forum Capturing and VCRReplies: 31Last Post: 15th Jun 2007, 15:08
