I finally finished my edited video, but when I do multiplex and add the video to the edited sound I have created(mp2 file) I get a warning message at the end saying
"12656 s packets cause buffer underflow.
The MPEG file might cause error when it played."
The video plays normally and the audio is ok, but gets a little distortion at certain parts in the audio.
Is there any way to change this?
Results 1 to 9 of 9
Oh, yes. Change the way you edit the files and most probably the error will change also.
Do some searching on the net and you will be able to fine a MPEG2 capable version of Virtual Dub. Im not sure its an offical release. It gets the job done, might be a little buggy, but free is free.Originally Posted by Abond
Pff, then try to run a mpeg2 "through" these versions to see what will happen.Originally Posted by qubesquare
I just did, I didnt get any problems. The only notice I got was it didnt like the Divx versions of drivers I had, but the tools worked fine for mpegs. After it parsed the mpeg file i was able to apply filters just as in the virtual dub meant for Avi's.Originally Posted by Abond
Then this is how you want to correct audio synch errors in a mpeg2 file??? (this was the question asked)Originally Posted by qubesquare
It can't hurt to run a 'scan video stream for errors...'. VirtualDub is like a swiss army knife in the battlefield... use it to operate until you get a hold of a scalpel.
Multiplexing error using the film machine
By adidas36 in forum Video ConversionReplies: 4Last Post: 16th Nov 2010, 16:55 -
After Effects error: opening sound component (-2166)
By santolina in forum EditingReplies: 0Last Post: 24th Apr 2010, 08:36 -
Getting error sound, but no error.
By chewie8008 in forum ComputerReplies: 3Last Post: 10th Jan 2009, 02:32 -
TMPGEnc Plus Error!
By redtrigger in forum Video ConversionReplies: 15Last Post: 9th Jul 2007, 11:05 -
TMPGEnc Plus and AVI sound
By busdonic in forum Video ConversionReplies: 5Last Post: 22nd Jun 2007, 10:18
