I have a Magnavox MRV640. Doing OK, until couple of weeks ago. Disks (all +RW and recorded on this Magnavox) came up "No Disc" when I tried to play them. I would wipe them off with a clean cloth and put the disk in again. Rarely did this make a difference. Once in awhile, after the wipe the disk could be read. Sometimes timed recordings would not be recorded. It does read commercial disks OK. This is the same problem I had before the Mag when I had a Philips. I called Magnavox. Sent me a CD to fix the problem (ala Philips). Nothing changed. I can play most of these disks on my Cyberhome player. But that's not so great--sometimes skips. I have tried other recorders--Sanyo, LiteOn, Cyberhome--and none were as good as Magnavox-Philips as far as layout, ease of recording, etc. I liked everything about the Mag-Phil except the trouble, which would happen about 18-20 months after my purchase.
Anything I can do to read these disks? Is there a more reliable recorder? I am on a budget. Like the info I've read on Panasonic ES15, but don't want to keep buying recorders that only perform well for a few months.
Thinking may be I should toss the DVD recorder and use only my Sony VCR. It's very reliable. Any suggestions?
Try cleaning the drive.
If that fails to remedy the problem, try changing the drive. With DVD-writers under $30 and recorders at $100 or more it is work considering.
See if the forums on www.cdfreaks.com have anyone else's experienes in changing the drive in your brand of recorder.
18-20 months is a pretty good life for a DVD-writer in heavy use without cleaning or adjustment, -
How do I clean or change the drive? I'm not hi-tech geek. Tho I'd like to be.
Buy a lens cleaning disc (available at most stores that sell CD/DVD accessories) and see if that helps.
LG DVD Recorder Hard disk Upgrade
By pchan in forum DVD & Blu-ray RecordersReplies: 39Last Post: 20th Sep 2016, 16:00 -
how or where (if you can) can you format a dvd disk with no recorder?
By noclue in forum Newbie / General discussionsReplies: 3Last Post: 19th Oct 2011, 13:11 -
I want a Hi-def hard disk recorder with no monthly fee
By adagio in forum DVB / IPTVReplies: 5Last Post: 31st Jan 2009, 21:41 -
DVD Recorder hard disk to PC
By aqctv in forum DVD & Blu-ray RecordersReplies: 5Last Post: 21st Jan 2008, 16:36 -
Disk burning issues with Toshiba HDD Recorder
By leafslover in forum DVD & Blu-ray RecordersReplies: 1Last Post: 17th Sep 2007, 23:39
