AutoGK installs VirtualDubMod v. 1.5.4, but the latest version is 1.5.10. Is it possible to simply overwrite the installed version with the latest version of VirtualDubMod? And if so: is it of any use?
Your views / comments are much appreciated!
Hi-
Yes, you can replace one with the other if you like. AutoGK doesn't care. Or you can have them both on your computer. I do.
Not to me, it isn't. I prefer the older 1.5.4.
pctv TVCenter versions & multiple installs
By Davalan in forum DVB / IPTVReplies: 0Last Post: 15th Apr 2011, 04:35 -
What should I use instead of VirtualDubMod?
By OM2 in forum Newbie / General discussionsReplies: 7Last Post: 14th Feb 2011, 02:06 -
Need help with VirtualDubMod
By Brakiri in forum Newbie / General discussionsReplies: 3Last Post: 17th Dec 2010, 05:28 -
transfer programs across xp installs (on 2 different hard drives)
By greymalkin in forum ComputerReplies: 2Last Post: 17th Nov 2009, 05:11 -
AutoGK prob - VirtualDubMod crashes on open
By Djinn252 in forum Video ConversionReplies: 8Last Post: 7th Jan 2009, 10:23
